Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > Boxster & Boxster S (986) Forum
Sign in using an external account
Register Forgot Password?
Search
Thread Tools Search this Thread
Old 09-10-2012, 01:18 AM   #1
Porschephile 924
Wax On, Wax Off
Porschephile 924's Avatar
Boostin 5280
Default P0507- high idle
I got a check engine light today. A P0507. Ran fine other than a 1200 RPM idle. I cleared the code, and since its been fine, idling at 600 RPM. Any suggestions? Thanks!
2002 Boxster S-rainforest green on tan, and stock
2000 BMW 540i Touring- stock...
Gone but not forgotten:
1987 924S
1988 944 Turbo S- Rogue Tuning M-Tune, 18 PSI, Lindsey Stage II intercooler, Tial wastegate, SBC-iD boost controler. 310 RWHP, 351 ft-lbs on pump gas
Porschephile 924 is offline   Reply With Quote
Old 09-10-2012, 05:34 PM   #2
Macster
Quote:
P0507 - Idle air control -- engine speed too high.
The ECM controls engine idle speed to a specified level through the fine adjustment of the amount of intake air which is let into the intake manifold by the operation of the electric throttle valve control actuator. The opening of the throttle valve is varied to allow optimum control of engine idling speed. The crankcase position sensor detects the actual speed and sends a signal to the ECM.
Possible fault causes: IAC valve is sticking or air cleaner blocked.
With a Porsche diagnostics computer this valve can be activated/tested. Clicking should be heard.
How to diagnose this/eliminate the IAC without the diagnostics computer's ability to control this hardware directly I have no idea.
And, there is the air cleaner possibility.
Sincerely,
Macster.
Macster is offline   Reply With Quote
Old 09-10-2012, 06:00 PM   #3
Porschephile 924
Wax On, Wax Off
Boostin 5280
Awesome. Thanks Macster!
1987 924S
Old 09-10-2012, 08:10 PM   #4
Domer911
User
Domer911's Avatar
Sincerely,
Macster.
^^^this kind of stuff is literally worth the price of admission!
Domer911 is offline   Reply With Quote
Tags
996, adjuster, air, boxster, cleaning, code, control, idle, location, p0507, porsche, speed, switch, throttle, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright © 1998 - 2007 Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
Emails & Contact Details
