ROW M030 Suspension.
Basic Sponsor
Rennlist,
Porsche just started showing stock of the ROW M030 suspension for the 986. We have been out of these for quite some time and a few of our preorders for the 2.5/2.7 liter are due by the end of this month.
Click here for more info on the ROW M030 kit.
If you have any questions please feel free to ask. We will be happy to help.
SuncoastParts.com
Your #1 Source for Genuine Porsche Parts and Accessories on the Web!
Visit us at http://www.SuncoastParts.com
Call us at: 877-923-1700
Email us at: Parts@SuncoastParts.com
Follow our Project 718 Build Thread!
Stay connected:
Join Our Newsletter
Facebook
SuncoastParts.com
Stay connected:
Join Our Newsletter
It's moot as I'm nearly ready to trade in my 986S for a 987S, but I was looking for US M030 parts for the longest time so I could stay stock-class legal in SCCA autocross. Was frustrating that ROW M030 was not only better performance, but cost half as much!
I recall seeing a chart listing suspension specs (anti roll bar diameters and spring rates) for the various Boxster iterations. Unfortunately, I can no longer find it. I also recall that the difference between the OEM US spec for the '03-'04 cars and ROW M030 is not significant. Can anyone confirm or deny any or all of this?
Near as I can tell, Boxster M030 (US & ROW) front and rear (19.2mm) sway bars are the same as base Boxster S came with from the factory. I was never able to find a conversion between spring color codes and actual spring rates, but the spring color codes are definitely different. They're even different between manual and tiptronic!
Boxster M030 (US & ROW) front and rear (19.2mm) sway bars are the same as base Boxster S came with from the factory............................. well i didn't know .... so thanks for the info in fact i m interested into changing the front right suspension of my cayenne so is there anone who could help me out i really don't have any experience into such things.... first i thought that the front right side might be down due to the shocks, springs but now i fell the inner shock is also bad and doesn't came back to the original position......
As far as swaybars go on Boxsters, I personally prefer GT3 swaybars, as they're adjustable and let you tune it out precisely how you want it.
cheap car rental surfers paradise
The rear sway bars are the same but the front are bigger. I have the measurements at my shop but not at home.
The car is significantly tighter and handles fantastically.
Probably the best upgrade I have ever made...
I have to imagine the rear spring rates are upped, if only the front bar rate is increased. Or else the relative ride heights change, with the M030 spring set. Only other thing I can think of is that the front drop allows some pick up in static negative camber and the increased roll stiffness of the front bar keeps the car from going as far into camber curve.
Just for a point of reference:
As of the 2003 model (facelift) the base Boxster adopted the prior-versions (pre-facelift) S suspension. In other words, the 2003-2004 Boxster had in general the earlier Boxster-S suspension specs.
Obviously as of 2003 the Boxster-S then stepped up the suspension above the then base Boxster.
Nevertheless I ordered one of these kits from Suncoast for my '98 Boxster & will be installing it shortly. My 2003 Boxster will remain stock for comparison sake. I will hope to have the same raves as posted above.
Wondering if the 2000 ROW Boxster S setup will fit on the base 2000 Boxster. They are listed as different numbers, but can't find anybody to tell me if they will fit without ruining the cars geometry
