Boxster & Boxster S (986) Forum 1996-2004
It must be my transmission mounts?
Old 01-15-2013, 02:06 PM
Po924S
Po924S's Avatar
Default It must be my transmission mounts?
I can only assume it isn't my motor mount because vibration isn't really an issue with my. If I don't shift it smoothly enough I get this clunk! For instance if I left of the gas all of a sudden, etc..etc. so before I get down and look it sounds like the transmission mounts, yes? Keep in mind the car has 127 thousand miles on her.
Old 01-15-2013, 03:13 PM
Macster
Macster's Avatar
I feel like I'm coming in the middle of a conversation but the symptoms do not sound like a transmission mount, even a motor mount, but a dual mass flywheel that has had the dual mass feature fail.
Old 01-16-2013, 02:20 PM
TroyN
TroyN's Avatar
I think the motor mount is more likely to wear/fail than the trans mounts.
Old 01-19-2013, 12:34 PM
Po924S
Po924S's Avatar
Hmm, I will have to look into that. Sounds terribly expensive!
This is my hope. Hopefully I will be able to get a closer look this weekend. I researched it and my only issue is that clunk noise when I don't shift smoothley. No vibration problems at any speed, or idle...etc.
Old 01-19-2013, 01:13 PM
Macster
Macster's Avatar
In my 02 Boxster an engine mount was found to be cracked (the rubber portion not the alum. casting into which the rubber was bonded) and replaced.
It was news to me it was cracked for I had no sign anything was amiss.
After it was replaced I had no sign of any improvement.
If you are not smooth with the shifting, clutch engagement there can be some clunking arising from the normal driveline play/slack being taken up.
IOWs, the noise/clunking you hear/experience may be normal.
Concentrate on smoothing up your clutch work.
If smoother clutch work doesn't have the clunking absent then the dual mass flywheel becomes a more likely scenario.
You can also just take the car in and bring this to a tech's attention. I'm sure he's encountered enough bad dual mass flywheels in his time to make a diagnosis.
Old 01-22-2013, 01:54 AM
Po924S
Po924S's Avatar
Turned out it was the motor mount. $540 for everything including tighting all of my cv boot bolts back (said they where loose?). The bolt thing...eh I could had done myself maybe, but I think I will let a professional repair anything engine related
Old 01-22-2013, 03:24 PM
Macster
Macster's Avatar
Motor mount it is then. Glad to read you got it resolved.
Quick Reply: It must be my transmission mounts?
