Top replacement
Top replacement
Looking for some advice on recent experiences.
Local installer highly recommends Robbins/GAHH. Said origin OEM was GER A5 DBS, but could also go with GER A5 or TWK II.
I am also interested in upgrading to glass window.
Robbins is a $1,000+, I've seen others through distributors around $500 or less.
Installation is another $500.
Any roses or thorns for certain manufacturer or suppliers?
Should I break open the piggy bank? Thanks in advance!!!
Are you sure you want the glass window top? The top has a different shape, the window is smaller and not positioned the same and interferes with putting the top in the service position to access the engine bay from the top.
I am considering the DIY, but haven't seen any clear write-ups addressing the headliner on the 'S'.
Bottom line, from what I've found, DIY sub $500 ordering top online from distributor, verse complete install for $2,000+.
IIRC GAHH bought out Robbins a few years ago.
I went with a glass window/defroster top on my NA Miata last year. I'm not sure I'd do it again. The clarity is wonderful but the smaller size top-to-bottom makes rear vision dodgy - I have to "duck down" to see distant objects in the rear view mirror. And engine access isn't an issue with the Miata. My cars are garaged so who cares about the defroster anyway.
Another supplier is EZ-on Tops which is supposed to be a close rival to Robbins. This places sells both so you may get an honest view from them. http://www.topsonline.com/
Plastic rear windows are replaceable. My dealer replaced mine while it sat on his lot for sale for 6 months. Presumably an "unexpected cost" for him. Upholstery shops can just sew a new one in place. Mine leaks slightly through the stitching so I'll have to seal it with seam seal compound.
What DennisAN said. I've had the one in my '02 Boxster replaced. A local auto upholstery/top shop did it. Nice thick plastic. The negative is the shop cut the old window out and left the edge in the canvas then sewed the new window in. There are two lines of stitching and a slight ridge around the window from the double thickness of plastic.
But the window is water tight, has not discolored. I no longer lower the top so the window has not creased, cracked or failed in any way.
I understand that if the rubber sheet under the canvas is ok just the canvas can be replaced. For the motivated this can be a DIY job. There have been some write ups on it. On another board (Pedro's Board) there is a person there who in my opinion is a top expert. Unfortunately I can't recall his name but a search of threads about Boxster tops should turn it up. Then you can search out posts on how to do the canvas swap.
Not sure how much this job costs at an auto upholstery/top shop or at a dealer.
I'm thinking the next time the rear window needs doing in my car I'll just have the canvas with a new window already installed replaced.
Basically that is what I did. Called two dealers, spoke to service managers, told them I had a 12 yo Boxster and was looking fior a top without breaking the bank and they both offered up their third party supplier. They didn't think twice. Gave it right up.
Dealer quotes approx. $3,200, third party $1,800-$2k.
hey all
friends plastic rear window cracked in his 02 boxster.
hes been quoted $700 to sew a new plastic window in there by a rag top shop...
sound ball park?
fyi we are in vancouver canada so prices will be more than in the us.
thanks!
sound ball park?
thanks!
