Boxster & Boxster S (986) Forum 1996-2004
986 seat belt buckle replacement
Old 03-30-2014, 06:44 PM
pbkirby
pbkirby's Avatar
Default 986 seat belt buckle replacement
Anyone know who to unplug the cable from the seat belt buckle from the wiring harness under the seat ? I got the seat out but cannot seem to remove the blue plug from the harness to install the new buckle.
Old 03-31-2014, 12:09 AM
Mighty Shilling
Wax On, Wax Off
Mighty Shilling's Avatar
Honestly that is the least helpful photo I have ever seen. Anything a bit more clear?
Old 03-31-2014, 07:57 PM
pbkirby
pbkirby's Avatar
Default Hope these are better photos
Appreciate any thoughts
Old 04-01-2014, 12:26 AM
Parrot356
Parrot356's Avatar
Where you able to disconnect the wire harness from the car. If you haven't, there is a slide safety on the side of the plug. Pull it out and the connector will release. To get the actual seat belt harness out there is a small almost square black plastic piece that you slide up and off (I used a screw driver). Once it is off the harness comes right out. Fish the new write through the seat, clip it in place and you are good to go.
Old 04-03-2014, 02:48 AM
RedTele
RedTele's Avatar
Read through this:
http://gallery.rennlist.com/gallery/album651
It shows how the connectors seperate.
Rick
Old 04-19-2014, 09:03 AM
pbkirby
pbkirby's Avatar
Default Thanks for the replies.
Fixed
Quick Reply: 986 seat belt buckle replacement
