water pump
I'm sure dealer prices have gone up. My local dealer has increaed its hourly rate to $160 (it was $150) an hour. (And still the service department has so much business an appontment is weeks out.) Parts prices have gone up as the dollar's value has surged. (But its high price has helped lower the cost of oil -- of course increased production played a role too.)
I order my pump from SUncoast and did it myself. They might be changing all the hoses and replacing the "lifetime" coolant. The white stuff on the hoses is from the pump weep hole, not a leaking hose. Didn't change them nor the thermostat, unless you have a problem with the thermostat.
The labor cost to replace a failed T-stat is pretty much the same labor cost to replace the water pump/T-stat. All one is out is the extra parts cost of the T-stat and the gasket.
The above is worded a bit awkwardly. The point I wanted to make is one doesn't save very much money at all by skipping replacing the T-Stat when he replaces the water pump. And if the T-Stat needs doing at some later date the cost to replace just the T-Stat is very close to the cost to replace the water pump and T-Stat. About the only difference if one is back at the engine to replace the T-Stat is he doesn't have the cost of the water pump.
I just did this myself recently. It's not a hard job and there are a few good videos on it as well. Just make sure you have a flex joint socket adapter. Its a must for a couple of the bolts.
