2008 Cayenne Turbo - PDCC Rear Line Burst
Follow up post,
Replaced both rear PDCC lines. It appears Porsche at some point in time revised these lines as the ones I received were no longer steel braided but very tough thick rubber for hydraulic systems. Much more confident inspiring. Had to drop the exhaust muffler down as well as the sway bar itself in order to have the proper clearance. Definitely recommend having a friend help with this job if you are a DIY'er.
Test drove last night and this morning. Everything seems to be fine. I don't have the program to perform the bleeding procedure so I would top off the reservoir, drive around for a little bit and pull over and top it off again until all the little air bubbles were gone. I will continue to monitor the PDCC reservoir for the next couple of days.
Will update if need be.
After mine went the first time, the updated replacements failed a further 2 times within 2 months with the Porsche supplied parts being replaced under warranty on each occasion. On the first occasion the pipe failed at idle in traffic and on the subsequent occurrences it happened whilst pushing hard on the same sweeping right hander. I've had a borrowed oil distributor fitted on trial for the last couple of months with no further issues.
Where did the replacement lines fail at? And are these the rear or front pdcc lines you are referring to?
I know there is an official bleed procedure but I just drove around town with lots of turns for 10 min. Park and top off. Repeat a couple more times and level hasn't changed after 3rd time.
Cheers,
TomF
Anyone getting chassis system warning when they are taking very hard turns? Happens to me now, I'm wondering if its happening because there still might be air in the PDCC system? When I turn the car off and restart it the error is no longer present.
Follow up post,
Yes, now I need to inspect my front lines as I most likely will want to replace them too.
Mine were on the front anti-roll bar and all failed at the swage. Only on the 3rd time was there any significant oil loss.
Based on earlier reports of the front lines failing dye to exterior abrasion, I actually took mine loose and purchased some clear heat shrink tubing that would fit over the metal threaded end, cut a section to length for the hose and shrunk it down over the braided stainless casing. I figured this would help protect the line and maintain its integrity, but this is a different type of failure where it looks like it failed internally rather than from exterior abrasion, so now I may not have accomplished anything
On the failed line you removed, what material is inside the stainless carcass - is it rubber, Teflon, or something else. The better stainless brake and power steering lines are braided stainless over Teflon with a rubber protective coating over the stainless. If the OEM lines are just rubber inside (including the upgraded replacements that have re-failed), maybe I should look at having some higher quality ones custom made with the proper construction, with the right lengths and ends on them.
Judging from my observation it was an internal rubbing issue. Not sure of the material inside (I'd lean towards teflon), but possibly the internal hose expanded to the point where it was constantly touching the stainless braided portion, and this internal friction along with the heat/pressure caused the brown spots. This in turn will eventually lead to a burst. I'm going to check my front lines for any of these visual brown marks and if I see them, going to replace the lines immediately.
As expected, the line was split on the inside. Looks like PTFE hose material, definitely not rubber. Either way, too thin for my tastes. Although PTFE should be adequate for this application? Maybe we ended up getting a poor quality PTFE from the factory, who knows. Perhaps these lines see a bit more heat and pressure than engineered for.
