2008 Cayenne Turbo - PDCC Rear Line Burst
Old 09-16-2017, 08:22 PM
killer2001
killer2001's Avatar
Default 2008 Cayenne Turbo - PDCC Rear Line Burst
Hey all,
Was driving home today and about 1/2 mile from my house after taking a hard left turn I heard a loud popping sound followed by the "Warning Chassis System" message. I got home and parked the car and saw fluid dripping out the rear. At this point I knew it was PDCC related. This is what I found...
I don't really understand how it could have burst considering its not touching anything. Odd.
I would like to know where I can purchase (both) of these rear lines. I tried looking online but can't seem to locate a parts catalog anywhere.
Also any tricks or tips into replacing these lines and procedures to follow would be greatly appreciated, I will continue to search for answers.
Old 09-16-2017, 09:27 PM
v10rick
v10rick's Avatar
Porsche identifies this as a stabilizer pressure line.
Follow this link to just one of many parts suppliers
https://www.porscheatlantaperimeterp...535912001.html
There have been reports of PDCC components failing. One aspect of owning a Cayenne.
Old 09-17-2017, 12:01 AM
killer2001
killer2001's Avatar
I believe that is a diagram of the front PDCC lines? I was able to locate the part #'s for the rear lines, they are:
955-359-121-02
955-359-122-02
Old 09-17-2017, 02:40 PM
user 83838290
user 83838290's Avatar
Don't even start it if you lost oil.
If you don't, you manage replace the lines and bleed the system, your tamdem pump *might* still be working.
I had to drive the car and had to refurb / replace the PDCC / servo pump. Not really cheap FYI.
Old 09-17-2017, 04:10 PM
killer2001
killer2001's Avatar
Anyway to know if the pump is still good? It was still dripping out fluid by the time I got home, luckily I was pretty much already home when it happened.
Old 09-17-2017, 04:11 PM
user 83838290
Yes, you repair everything without it running, fill it up, bleed and see if it works
Old 09-17-2017, 04:15 PM
killer2001
killer2001's Avatar
I really would like to move it one spot over in my driveway. If I were to top it off and move it over real quick, think that would be ok?
Old 09-17-2017, 04:24 PM
user 83838290
I have no idea, but if you cover the hole temporarily with a stainless steel screw tie (not sure if that's the correct name for it, I mean this : http://www.autodily-online.cz/soubor...1/sk_pasek.jpg ) it should work. Then again, your pump might already be shot.
Old 09-17-2017, 04:45 PM
killer2001
killer2001's Avatar
That sounds like a good idea. Maybe a piece of duct tape first, then a clamp just to limit the leaking while I move it over 6 feet.
Old 09-17-2017, 08:13 PM
touareg
touareg's Avatar
Hose Clamp
Old 09-17-2017, 08:14 PM
touareg
touareg's Avatar
Sorry for your loss!
How many miles? What kind of climate do you live in?
Possible road debris hit it?
Hey all,
Old 09-17-2017, 09:57 PM
killer2001
killer2001's Avatar
107k. Florida. It burst where it was brown and discolored if you look at the pic there are other brown/discolored spots.
Old 09-28-2017, 04:56 PM
killer2001
killer2001's Avatar
Follow up post,
Replaced both rear PDCC lines. It appears Porsche at some point in time revised these lines as the ones I received were no longer steel braided but very tough thick rubber for hydraulic systems. Much more confident inspiring. Had to drop the exhaust muffler down as well as the sway bar itself in order to have the proper clearance. Definitely recommend having a friend help with this job if you are a DIY'er.
Test drove last night and this morning. Everything seems to be fine. I don't have the program to perform the bleeding procedure so I would top off the reservoir, drive around for a little bit and pull over and top it off again until all the little air bubbles were gone. I will continue to monitor the PDCC reservoir for the next couple of days.
Will update if need be.
Old 09-28-2017, 09:11 PM
geetee
geetee's Avatar
exact same line burst on mine also. 135k NE salt area
the line in superceded with a "better" one like you mentions.
You do have to bleed it a few times to get all the bubbles out. Must make sure you have enough pentosin
Old 09-28-2017, 09:12 PM
geetee
geetee's Avatar
funny...i think my line burst on the same day yours did
Quick Reply: 2008 Cayenne Turbo - PDCC Rear Line Burst
