High Mileage ROLL CALL!
Old 04-23-2018, 07:51 PM
medtech
medtech's Avatar
Default High Mileage ROLL CALL!
Interested in hearing from some peeps that actually use their cars they way Ferdinand intended it!!
I will start with our 2006 Cayenne S with 195k, and still on the original air suspension, engine, tranny, and cardan shaft (with small mod).
How many smiles do you have??
Old 04-23-2018, 08:49 PM
95_993
95_993's Avatar
Nice!!! I've got a long way to go with only 66k on an 05 CS.
Old 04-24-2018, 12:08 AM
jeff spahn
jeff spahn's Avatar
Almost 190,000 on the Cayenne and 155,000 on the 928S4. 200,500 on the 99 C280 and 40,000 on the 16 Pilot (that's going away soon for a new one).
Old 04-24-2018, 09:52 AM
tomhartzell
tomhartzell's Avatar
122,000 on my Cayenne -- still very low mileage compared to previous vehicles. Sold Land Rover Disco with 312,000 on it.
'77 Benz had 325,000 when I gave it to my brother. He gave it to a friend at 450,000 when their car died.
Old 04-24-2018, 11:29 AM
Wisconsin Joe
Wisconsin Joe's Avatar
Almost 119k on an 05 CTT. It had 103k on it when I bought it 3 years ago.
Not terribly high by some measures, but the highest on a car I've ever owned.
Edit to add:
PO did water pump, air compressor, instrument cluster, brakes, battery and a wheel bearing or two.
I've done pipes & T, starter, hatch struts, Jimi fix and some paint work (couple rust spots & a scrape/dent).
Old 04-24-2018, 12:17 PM
user 83838290
user 83838290's Avatar
Search sucks on the garage talk app, a thread like this has been here since a couple of years. There's a member with over 300k miles on his pig
Old 04-24-2018, 01:48 PM
Dilberto
Dilberto's Avatar
Default Seeking 2006 CTTS Parts Car...
2006 CTT @ 115,700 miles:
Replaced:
- Water pump
- Serpentine belt, and rollers
- Turbo diverter valves
- Intercooler boost hose 0-rings 3x
- CV axles
- Coolant tees
- Coolant pipes
- Coolant reservoir
- Oil cooler
- Front lower control arms
- Hatch struts
- Starter
- Thermostat
- Differential fluid
- Transfer case ATF
- Transmission ATF and filter
- Xenon headlights
- Panoramic roof motor
- Hood strut
- Parking brake strut
- Battery
- PCV breather hoses
- PCV check valve
- Air oil separator
- Oil cap
- Cardan shaft
- Gas cap
- Lots of broken plastic parts...
Old 04-24-2018, 02:10 PM
Rossi
Rossi's Avatar
2009 GTS @ 98K miles:
Replaced:
- Water pump
- Water Pump Pulley
- Serpentine belt
- Thermostat
- Battery
- AOS
- HPF pump
- Cardan shaft support (Jimmy fix)
- Starter
Old 04-24-2018, 04:17 PM
Hams911
Hams911's Avatar
2011 s with 119k. Aside from wear items and transfer case everything keeps ticking!
Old 04-24-2018, 09:32 PM
dpatel710
dpatel710's Avatar
04 CTT with 195k. Everything has been replaced 2x over by this point but it keeps on going.
Old 04-25-2018, 01:43 AM
NelaK
NelaK's Avatar
09 CTTS at 190,000 kilometers
1x Coil pack
And maintenance items at their intervals.
I've bought a battery since the replacement batteries can be kind of hard to get where I am but I'm still a few months before it needs replacing.
Old 04-25-2018, 02:55 AM
porkandbeans
porkandbeans's Avatar
04 Cayenne Turbo with 204,000 miles.
Looking to run strong for a lot longer!
Old 04-25-2018, 01:57 PM
Shawn Stanford
Shawn Stanford's Avatar
'05 base: 152k. Replaced brakes, cardan shaft, fuel pumps, downpipes, blower motor and repaired floor-board water no-start. Keeps going.
Old 04-25-2018, 04:23 PM
Laura
Laura's Avatar
2006 Turbo S @ 270K, getting front end repainted today for peeling clear coat
Old 04-25-2018, 05:24 PM
GrandeOak
GrandeOak's Avatar
Love seeing all the high mileage turbos!
138,000 on my 2005 CTT daily driver - 23K under my ownership the last 2+ years and I swear it drives better everyday (probably due to all the new parts).
Quick Reply: High Mileage ROLL CALL!
