Porsche Composite waterpump pulley failure
This is crazy. I am still on my original which I assume is @ least 8 years old with @ least 115k miles. It even had a chip out of one of the edges and in the middle bore hole. I just radiused them off to get rid of stress risers and have not had any issue. Maybe the plastic formula changed once the was an established seller for Porsche.
I installed the Aluminum waterpump pulley and will report back if I have any issues going forward. One question for you DIY guys. When tightening the 3 torx screws that hold the waterpump pulley on......what wrench do you use? Because of clearance I took the 3/4 socket torx and clamped a vice grip on the hex portion of the shaft at 90 degrees. It works and there is no way to put the socket on the 3/8 wrench as there is no space. Curious what you guys use.
FWIW I have never seen a water pump pulley fail on one of these vehicles and I have been working on them since they came out in 2003. I have certainly seen them damaged while being removed and installed but I have never seen one fail by themselves.
Kind of like this:
since you regularly wrench on these, do you know if the metal ones that Porsche switched to on later ceyennes bolt up to the 1st generation?
MAYBE, the 2011+ looks aluminum... IDK on offset or diameter. Worth a try perhaps at ~$40 shipped.
OEM Number: 059121031H / 059 121 03 1H
GENUINE Water Pump Pulley
OEM Number: 059121031H / 059 121 03 1H- Porsche Cayenne 958 2011-
