Porsche Composite waterpump pulley failure
I just had the “guinuine Porsche” composite waterpump pulley fail. I had about 1500 miles on the new belt/waterpump/pulleys. I plan to use an aftermarket Aluminum pulley this time. What a “guinuine” JOKE.
Oh and and no I did not over tighten the 3 bolts. Most of the failure is at the outer area just inside the belt tracking portion.
You don't become the most profitable car company in world by making quality products.
That pulley needs to be replaced every time the water pump and serpentine belt is done... otherwise, the pulley "grows teeth" and will gnarl-up the serp in no time flat.
A heavy metal pulley is NOT the answer...
The pully was replaced...a whopping 1500 miles ago. Worked wonderful until it shttered like a clay pigeon. Probably designed by the same wizard that put plastic coolant pipes on the car. You sticking with the plastic coolant pipes?
This is not an isolated case. We have seen others who have thrown/shredded belts from the water pump pulley fragging. When I recently removed my water pump pulley to replace all the parts on the front of the engine, the old pulley was quite brittle and went kind of like this:
https://www.youtube.com/watch?v=HqZWsJ2oO_E
The aluminum pulley is actually cheaper than the plastic one. Seems like a no brainier to me. I wonder if Porsche will refund your money on the OEM one that failed?
https://www.ecstuning.com/b-hamburg-...810609001~ham/
Lots of interesting info in this thread. I too have sworn off Hamburg Technic (100% pure Chinese, in case you are thrown off by the name they chose, which should be a clue as to their honesty). But something like an Aluminum pulley - really not much to go wrong there. But I still would stay away from them.
So do I, but it's a simple pulley made out of aluminum. What could really go wrong? As for longevity, I would put my money on that aluminum pulley over the OEM plastic one every time. Sometimes for simple things like this, choice of materials is more important than a brand name.
Hilarious. "one of a kind piece ... no other one like it in the world ..." Yep, I saw that one coming a mile away. And the host's reaction is pure savage.
If knew there was a chinese aluminum pulley, I probably would have tried it. I will take a minor balance issue over having a cheap plastic pulley grenade every time. I have balanced enough props from 5cm to 140cm that I am pretty sure I could get check it quickly and get it dialed in if it arrived poorly made.
My car is already on it's third OE plastic water pump pulley and the car hasn't even hit 80k miles. How much worse can it get?
If I would of known there was a metal water pump pulley available, I definitely would of went that route.
This is crazy. I am still on my original which I assume is @ least 8 years old with @ least 115k miles. It even had a chip out of one of the edges and in the middle bore hole. I just radiused them off to get rid of stress risers and have not had any issue. Maybe the plastic formula changed once the Cayenne was an established seller for Porsche.
