best scanner to buy for porsche cayenne (1st gen)
so i have been doing a bit of info on the first generation cayenne cause i have always wanted one and since there's an existential amount of problems with the 03-04 4.5L V8 its fallen into my price range and since im new to porsche i want to cover all the bases before buying one and what better to cover those bases than a scan tool but i can't figure out which one to buy i was looking at the icarsoft por v2.0 but would like the tool to diagnose more than just a porsche and a handful of other european cars so thats what drew me to the icarsoft pro which does porsche and basically any other car manufacturer but im worried if i get either scan tool and i cant reset the steering fault system on the cayenne i'll be stranded as i plan on buying this car in california and driving it all the way back to buffalo,NY so basically my question is can any of these scan tools help me with this and if not which one not listed here can honrable mentions would be the autel mk808 as i was looking at that one to
I have a Foxwell NT520 Pro (3 actually, for my Porsche, BMW, and Honda - although I could have one with 3x software loads), and it seems to do what I need, which is not much so far. So it is great, easy, but mostly un-tested.
But I wanted to commend you on the plan to buy a car here in CA and drive it back to NY. I'm surprised more people don't do that. Having grown up in PA and Boston, followed by 30+ years in CA, it is amazing how differently the cars age out here. And as far as I can see, the prices don't fully reflect how much better condition the CA cars are. But I hope you've budgeted a few $k for gas money getting it home.
And BTW, I just thought of 2 reasons that CA car prices are suppressed ... one of the many areas we lead the nation in is gasoline taxes ... the other one is ridiculous regulation, insurance costs, and employment taxes, resulting in extremely high labor costs for those who don't DIY. So it may not be hard to find someone here in CA with a car in great condition who is unloading it just for those two reasons.
The iCarScan is cheaper and also works on my Mercedes (5 license option).
I've got both, but prefer iCarScan. It's mostly because I hate lugging the laptop out to the garage. From a functional standpoint they are pretty similar, though Durametric may be a bit more obvious/intuitive.
which Icarscan do you have though the Porsche version or the pro version?
Received 1,143 Likes
I also have both. The Durametric came out about a year ago when I bought the Boxster - I just was curious about the RPM range readings (not really a worry with the PDK transmission though.) Other than that - the iCarScan goes to work. Easy to connect with a cellphone and easy to transport and use. On trips, it gets tossed in the driver's door pocket just in case. So far I haven't needed to use it on the road.
It comes with 5 different licenses for other marques. I did Porsche, MB, VW, BMW, and Toyota as that was likely to cover anything in my extended family. Note that they stop updating the software after a year or so unless you buy again. The device still works, you just don't get all the latest updates. For cars as old as the Cayenne, I've not found that to be an issue yet.
deilenberger (10-15-2020)
yeah sorry the typing format wasn’t letting me backspace, instead it was erasing what I was typing earlier if I went to go back and re-write on my mistakes
I bought iCarScan. Have ended up using it on my 2 Cayennes (Base/CTT). Bought additional downloads for my Tahoe/FJ. It's very helpful when you try to self diagnosis and trouble shoot.
I started to type "I use iCarScan," until I realized I use iCarSoft.
I keep the OBD cable connected and coiled around my steering column.
Whenever something exciting happens trouble-wise (rarely now-a-days) I can reach behind the seat for the tool in its zipper case and plug it up while driving.
The software could be written a bit better to save time, but so far it's worked for me. I've been able to:
Since there are dozens of things to test that come up with a communications error, the auto scan mode will waste like 3 minutes of your time only to spit out a communications error if memory serves.
So you have to hunt and peck through all possible systems to narrow down problems.
Otherwise it works for me. 3-1/2 stars out of 5.
- scan and reset airbag codes
- troubleshoot air suspension, tiptronic, PSM, and other issues related to bad wiring under the carpet
- troubleshoot a crankshaft position sensor (I think)
- track down vacuum leaks
- realize I had bad coils
- check battery voltage and sensor readouts
- reset stuff
iCarscan is awesome (purchased mine 3 weeks ago)!! While Durametrix definitely has its place iCarscan can do everything you would really need it to....and you can use it on other vehicles. Why pay more for a system that is limited to just one vehicle make?? Can't say enough good things about iCarscan.
