Best Plug and Play Head Unit for Cayenne GTS
I want to upgrade my head unit and was trying to decide which head unit is best without having to re-wire the interior of my car? A good plug and play is desired that still allows me to use my steering wheel controls and I have a backup camera.
08 GTS
08 GTS
Go to crutchfield and look. They have plug and play harnesses that integrate right in. Done in two cayennes now.
Keep in mind, there is no perfect replacement - you will lose one thing or another, so it's a compromise at best. Standard HU's, even with all the available harnesses and adapters, will lose trip/MPG readouts, and communication to the instrument cluster display. Some steering wheel buttons, too, depending on what you have and where you're going. Also, I think you will have to run an external mic one way or another.
With Android HU, you lose some reliability and ease of use, maybe the AM/FM radio in some cases, but you get to retain some communication with instrument cluster depending on the model.
For the backup camera, I don't think it'll be a straightforward P&P, as the factory camera needs to be energized differently if I recall correctly. Look into it further if it's a must-have.
I had a Bluetooth adapter for the original PCM2.1 for a while before I went to an AndroidAuto compatible Kenwood unit. The BT unit worked great with the factory stuff. When I went to aftermarket HU, I gained AAuto, but now have to live with worse AM/FM reception, the thing auto shuts off a few seconds after you pull the key out (I'd get 15m or so with factory unit, and a warning before shut-off), steering wheel buttons are off (volume and up/down work, others do functions that don't correspond to the image). Aftermarket has nowhere near the polish of a factory system.
