Did you just replace the line with oem, cut it shorter or use something aftermarket?
I used 1/2" dia heat shrink temporarily until I replaced with OEM. I would definitely replace it....once it starts to split, it's brittle and essentially shot. Easy swap. Hardest part was removing wiper arms.
