Oil strainer for the camshaft actuator
Hello,
For Cayenne 4.5 turbo, year 2004, how do you replace oil strainer for the camshaft actuator (99710570100 part #20 in picture below)? It`s impossible to get it out from top, it seams stuck in.
Does it come out by force or there is any other tricks?
Mid 2005 and earlier were just a check valve no strainer, it's metal and it's staked in the bore. Later was a plastic strainer incorporated with the check valve (as in your pic) and easily removable.
