Porsche factory rock sliders...
Looking for some factory OEM rock sliders (not step) for my 2010 Cayenne.
I found some on Eurowise and it was spefic to the 955 (Gen 1 2003-2006). However, I've heard from other members that they are the same between 955/957.
Does anyone know if this is correct or if the parts will fit on my truck?
https://shop.eurowise.com/products/ewor955sl1
Thanks guys!
PS> if anyone has a used set they would like to sell, please let me know!
Thanks guys!
It looks like they might be different. My suggestion would be to call your local (or any) porsche parts department and ask them to check:
957 is, I think: http://www.autoatlanta.com/tinyresults.php?pn=955559848034W9
995 is, I think: http://www.autoatlanta.com/tinyresults.php?pn=955559847014W9
based on these two parts diagrams:
957: Linings Accessories Door Sill (autoatlanta.com)
955: Linings Accessories Door Sill (autoatlanta.com)
FWIW, I too would be picking up a pair if they were not so $. As-is, I plan to get a local shop to fab something discrete and stout, at some point.
The other one I feel worth mentioning is (#10 in the diagram, and the "type 3" one is the steel one, I believe).
Lining Underbody Heat Protection (autoatlanta.com)
the Transsyberia steel underbody protection. This is the section behind the chin, in front of the tranny, basically under the oil pan and tsfr case, IIRC:
http://www.autoatlanta.com/tinyresul...pn=95550423501
"Tougher than plastic, but not rock-crawling tough"
charsiuboar (12-01-2022)
Not a bad price on the TS underbody piece, any idea how thick they are? I can't seem to find any photos.
I have to say the factory rock sliders are pretty appealing to me but they are spendy. I haven't seen any aftermarket ones that look "right" on the car yet. I think that maybe round tube just doesn't suit the styling of the vehicle.
I'm agreed on the styling, though I wish they were black. Yes, Pricey, and no, not "robust" but better than plastic. The underbody has been reported elsewhere as "not very thick" but better than nothing. I haven't seen or touched it.
Found some pics here. Hard to tell the thickness but I'm guessing in the 1.6mm (0.065") range? Maybe a touch thin, but it's a lot of fab work taken care of for 300USD
https://www.ebay.com.au/itm/28418758...mis&media=COPY
Edit: just found a weight of 3.6kg. Must be pretty thin.
Ordered mine. Had the same thing in mind. Maybe even just bolt a sheet of flat steel to the now-cleanly-mounted "mounting plate"
