2010 Cayenne Base - Control Module or CAN Bus Issue?
SO, after deciding to call it a day until I could get a new 433 Relay, I put stuff back together to the point where I could re-position the Cayenne in the driveway & safely drive it if need be. When I re-installed the 433 Relay it went ALL the way into its Socket with a satisfying 'click' at the last moment. ALL the way as in NO 1/8" gap as it previously had. THIS caught my attention. Could I have been riding around for 7+ years with a partially inserted Relay?
This prompted a series of test drives around the neighborhood that got longer and longer and ultimately well exceeded the distance and time of what had been a very consistent failure scenario. Was this my problem all along? I shall see as I plan to put the Cayenne back into local service and see what happens. I could have 'magically' moved the right wire in moving the carpet away from the bundle but the way the 433 SNAPPED all the way into its Socket and ALL my issues disappeared has me hooked for now... :-)
Barry
Barry
I would suggest untaping that driver's side harness and inspecting the presumably repaired splices.
Barry
Well, it's been almost 9 months and the Cayenne has had no further occurrences of the 'System Fault'. Looks like the Relay seating may well have been the issue. Go figure...
Barry
Barry
The following 2 users liked this post by Barry A. Waters:
BobcatBrian (02-16-2024),
CaliforniaSurfer (02-15-2024)
