957GTS - Battery Ground Access
Hi all
Looking for some inspiration! I know where the access to the battery ground point is at the front of LH seat - through the lift-up carpet panel. However, no matter how hard I pull, tug, curse, I cannot get it to open. Does anyone have any suggestions (only polite ones please) or can describe what's holding it closed? I changed the battery 4 yrs ago but never knew about the access flap then.
TIA
H
TIA
H
The plastic cover has a few metal spring clips that hold ii in place. I use a flat blade screwdriver to pop the cover off.
