Anyone seen this? Engine had a poof of smoked and died. Wont start now.
The following 2 users liked this post by Malibu955:
BobcatBrian (12-21-2023),
oldskewel (12-21-2023)
Making progress.
Cheers, Mike
So I have a new CPS Sensor Easy to remove after I took off the 50lb 1/8" steel aftermarket skid plate LOL. Now I cannot for the life of me reach the connector. The wiring is snaked around the exhaust and the connector is under what I am assuming is the high pressure fuel pump. A can barely see it from the bottom and cannot at all see it or touch it from the top. Anyone got some wisdom here short of removing a portion of the exhaust to get it from below. Here are some pics of the connector, the empty location with it out and the connector in the dark distance.
Cheers, Mike
Looking straight up the drivers side downpipe
Cheers, Mike
IIRC I got mine from the top. I don't remember now, but my past self suggested using a long thin screwdriver to pick it off.
https://rennlist.com/forums/cayenne-...r-removal.html
Maybe @michadennis has a better recollection.
Found this too:
https://www.pelicanparts.com/techart...eplacement.htm
"You know it's funny what a young man recollects" -F. Gump
Found this too:
Just read through the Pelican DYI and its for an S non turbo and its a 4.5L which you can get to from the top. I cannot even get my hand behind the fire wall down past my wrist and cannot touch any connections on the back side.
Mine is a 4.8L turbo. Here is a pic of engine bay and looking down against the firewall.
Oh, sorry. I wish there was an easy way to put everyone's make/model near our avatar thing on the left.
This should help:
https://rennlist.com/forums/cayenne-...ement-diy.html
This should help:
Thank you all for the links and read ups it was very helpful. Recieved a new CPS and went through replacing .I removed the bolt holding the 90degree plastic wire holder or protector and it created enough room for me to grab the connector. I removed the connector off the mounting bracket using the worlds longest screw driver from underneath.
Once I had the clearance I used the old CPS tying a string to the connector as I pulled to old one up. This allowed me to fish the new one down routed as the factory one was .Once I got my hands on the connector this was not hard. Not realizing that moving the 90 piece would make a world of difference getting my fingers on it.
It's out and the new one is in. Found out it was not my problem but a new one is in non the less.
Ohm tested the old vs new and neither had dead shorts to any pins. The end to middle pin both tested similar. The new was .954K and the old was .976K resistance. Go figure.
Thanks everyone for you help. Hope this tread saves others time. Here is some of the pics of the 90 degree plastic thing I moved and the bolt location.
Cheers, Mike
Here is the harness bolt and the 90degree plastic I moved for access.
Lots of length to play with.
Cheers, Mike
All in new CPS - NO START still. WTF.
I went down the fuel pump side of the fence. Fuses 13 - 14 for right side and left side. I replaced both Relays just for fun and still nothing. Did the pull one fuse thing and relay removal to see if I can isolate where the problem really lies.
In looking at fuses I noticed fuse 7 burnt. It goes to the coil packs.
I replaced it and gave the car a try. Holy S#$& it started. Then I started to miss and a huge puff of smoke burst out of the rear of the motor. Just like when the car died the first time. Shut it down and smoke was pouring out and around the number 4 ignition coil or so I thought. It migrated along the cover and was coming out in several places.
This time I was in the garage when the car dies and it still smells like burnt plastic. Here are some pics up close at the #4 pack. Ever seen this before. After checking the fuse it was burnt out again. More to come as I remove it.
Cheers, Mike
Where smoke was coming out
Number 4 up close
Cheers, Mike
Number 4 up close
