Anyone seen this? Engine had a poof of smoked and died. Wont start now.
#33
I have a junk engine harness if you need a connector cut off with some wire. You could splice it in.
#34
Eventually I bought another full set of coils from FCP Euro and I haven't had any problems in the years or tens of thousands of miles since.
thesteve (12-29-2023)
#35
I have the full set of OEM Porsche coils I pulled from my Cayenne Turbo S when I preventatively replaced them a couple months ago. No misfires or running issues at all and no cracks on the tubes or insulators on the backs. If someone wants them as spares, we can work out a great price.
This is what the spark plugs looked like
#36
Originally Posted by notthd
Coil removed it is toast and so is the connector.
Oh well - so I found the "smoking gun LOL"
Cheers ,Mike
Cheers ,Mike
#38
#39
Cheers, Mike
#40
Local yard let me hack out a couple of feet of the coil harness for $20 bucks. "Winning" or so I thought. Spliced it in and put every thing back together and still no start and continuous turning over. Again WTF.
Went back and reconnected every connector to make sure they were engaged. Pulled every fuse and relay checked, ohmed, and reconnected to make sure contacts were made.
There is a GOD, it started. Drove it to the store, the autoparts place and the local cruise in and all is good. It actually seems to run better. Threw a code but haven't read it yet. My advice is to pull the ECU fuse to force it to reset or use a good scan tool to wipe it so all limp home or don't start stuff is clean and force the module to relearn the new parts.
It is my instinct and not knowledge of science. Something to try if you guys see similar. All for now. She is on the road again. Thank you to all.
Cheers, Mike
Cheers, Mike
phatz (01-01-2024)
