Anyone seen this? Engine had a poof of smoked and died. Wont start now.
Hey all,
Having an interesting morning. Pulling out of the drive way the engine bay made a poof of smoke (I have hood vents for turbo heat here in Az - aftermarket) and it rolled out of the hood vents then into the cabin. Not sure of the smell or just exhaust but no Antifreeze or coolant flavor to it. Then within seconds the motor died and it will not restart. No leaks from under and nothing looks out of place.
Any ideas out there as to what to look at first. It just turns over with no kick to it whatsoever. No noises, rattles, knocks etc and has been running perfectly. Does have 143K miles on her but no issues till today.
Snide or comedic comments encouraged, I could use them at the moment.
Cheers, Mike
Cheers, Mike
Scan for codes and report findings.
From the West side that's a long push LOL.
Only code registered was P2310 "D" primary control circuit high
I cleared it and tried to start and same thing. Turns over continuously until I shut off the ignition. Not sure that is normal. Once the starter is engaged it will keep turning over even with the key in Run position. Seems strange but OK.
All I know so far. Thoughts ?.
phatz (12-19-2023)
Is look around to see if the was a small wiring issue. A major short could cause the puff of smoke and some fried insulation and burned harness somewhere
Rodents have a tendency to check on things
I thought of the crank positioner also. Have'nt had time to check on it yet and figure out how to test it.
Some odd things that may be related. I off road my Cayenne and during a 70degree hill climb (yes almost straight up) I lost throttle. It would still idle but had no pedal. Once back on level ground problem disappeared. 1/2 tank of fuel when it occurred. Recently I had misfires occurring. I replaced coils and issue went away. A couple of months later I am getting "running to lean" codes intermittently on both banks. Keeps occurring but not constantly. Car runs or did run perfect. Wondering now if I had a fuel pump issue in one or now both.
Hummmmm????
Cheers, Mike
Hummmmm????
Cheers, Mike
BobcatBrian (12-20-2023)
Sounds like what I experienced when my first attempt at repairing this tube with regular heat shrink tubing failed (see link below).
The tube blew open and produced a puff of smoke. Then it wouldn't start again.
https://rennlist.com/forums/cayenne-...-tubing-2.html
Oh, forgot to mention, after using the proper high-temp, clear heat shrink, I eventually had to replace the crankshaft position sensor for intermittent no-starts.
This. When cranking the tach needle should jump up and down a little as it senses engine rotation. If it doesn't know where the crank is, it won't fire the spark or fuel.
My guess is the CPS failed, you got a backfire back through the intake from a mistimed fuel r spark pulse and now it can't see engine rotation.
You should also check the airboxes and filters to make sure nothing was damaged if it was a backfire.
Not sure what kind of car you've got there, but on my 2004 S when I was doing a compression test during my PPI, I found that the engine cranking would automatically stop after an exact amount of time (or maybe revs?), like about 10 seconds (i.e., even with the key still held all the way to START, it would stop cranking after 10 seconds). This was useful for repeatability in making good compression measurements. But anyway, for you, the fact that this feature to stop cranking seems to be gone might be a clue.
Other than that, I'm thinking some sort of CPS failure makes sense. Going all the way back to the sudden death and puff of smoke - maybe CPS failure caused a cylinder firing at completely wrong phase, sending smoke back out the intake.
Putting those together, if the stop-cranking code counts revs rather than time, and the CPS means it can't count revs, that would explain what you're seeing.
On this specific clue, minor comment ...
I ordered a new CPS for first attempt. Amazons for $14 bucks arrives today to troubleshoot and Bosch for Pelican parts arrives tommorrow. Hopefuly I can at least get it out of the street. My drive is narrow and slightly uphill. Welcome to Phoenix suburbia.. It is a 09TT. Thanks for the insight.
Cheers, Mike
So, thinking about a common point of failure that would take out all cylinders and won't throw a code, my wild assed guess is the high pressure fuel pump. Or it could be the low side pumps. At 143k, your low pressure pumps (in the tank) are beyond past due for change out. Is there a banjo bolt to access the low side and the back of the engine bay? I vaguely recall a simple inline disconnect joint on my 04TT (old school manifold mounted port injectors). There are two fuses (again in an 04) under hood in the cowl area...fuse numbers 13 & 14 in 957 (confirm which ones) .. that power the two pumps in the saddlebag tank under the back seats. Test the output of each pump by pulling one fuse, then put it back and pull the other. When mine died, one was completely dead and the other started going intermittent.
I don't know what code(s), if any, a failure of the high-pressure pump would throw.
Edit - I like the previously suggested emissions hose from the check valves to the intake manifold. The rupture would explain the puff of smoke and the break allows unmetered air which makes starting a challenge. You can remove the ends from the broken pipe and use some reinforced PCV rated hose. I did mine with reinforced silicone hose and hose clamps.
Happy sleuthing,
Brian
Happy sleuthing,
Brian
