2010 Cayenne Base - Vacuum Line Cracked
Can anyone identify this vacuum line? It's cracked on my Cayenne at the elbow next to the coolant expansion tank. The PET I have shows it but doesn't give much information on it. I'm wondering what it connects to after it disappears into the firewall (see red circle on PET diagram). The EVAP system perhaps? If anyone could provide a part number that would be grand.
Barry
Barry
95535557941 is what I used on my 2009 base.
Rein 06F103235A is a cheaper alternative to #7, this one breaks as well if you pull the intake or disturb it.
Mark
Mark
Barry A. Waters (02-16-2024)
Well, that's ONE mystery solved. Here's a supplier's image flipped over so it's oriented properly. The area circled in red is where my problem occurred. Still wonder what that end connects to though BUT this is indeed the part. Thanks Mark! :-)
Barry
Barry
After considering replacing Vacuum Line 6 (see PET page image in Post #1 above) I've got more questions. Apparently I could have a Vacuum Line 4 to Left Front of Manifold and a Line 5 whose name or purpose I know not. Does anyone know if these are 'hard' plastic lines like Vacuum Line 6 is? Probably more important is access to the Vacuum Pump connection (and to wherever Line 5 might run if I have that line). With the engine beauty panels removed I can't even see the Vacuum Pump much less understand how I could remove/replace Line 6 from it. Does this mean that the Manifold needs to be removed to access it? THAT would be a royal PITA. Has anyone been through this before (Vacuum Line 6 or Vacuum Pump replacement)?
Barry
Barry
From what I recall line 5 and 4 were rubber hose. Neither gave me any trouble when removing my intake. They most likely can be replaced with the correct size silicone hose in a pinch.
Mark
Mark
Barry A. Waters (02-29-2024)
Line 9 goes to the evap emissions charcoal canister via the electric valve.
Line 7 goes to the PCV valve.
Line 6 goes to the brake booster.
Line 5 supplies vacuum to something behind the engine bay. Probably the leak detection pump.
Line 4 goes to the intake resonance flap valve.
I believe 4 & 5 are either all rubber or might be nylon with rubber connectors. These are small lines, perhaps 6mm.
Great replies above from mdistel and theprf but the question of access to the vacuum pump and its connections remains. Does the Intake Manifold have to be removed to get to it? That would bring into play other things prone to breakage like the 'crackpipe' and stuff. I'm a bit leary of collateral damage at this point...
Barry
Barry
Barry
Barry
Since the crack/solit is just on the end, slide some heat shrink tubing over it, put the fitting in and shrink away. Will work while you sort out replacing the line. I had to do the same on my brake booster line until I could replace it.
Barry A. Waters (03-01-2024)
On another thought, I'm assuming that Porsche went with this rigid plastic line to insure against the lines collapsing under high vacuum conditions. This would be a consideration if you want to replace them with rubber hose. Make sure you use hose that can take the max vacuum the system can generate without caving in on itself either at first or years later after 'aging' for a while under in-service conditions!
Barry
