DenisonUSA: new look website, update
Old 05-25-2005, 06:01 PM
mudman2
Moderator !x4
mudman2's Avatar
Me to ! thats just wasted energy I listen to my iPod and Sirius everyday and they sound great to me. I would change to the new device should it ever appear.
Old 05-25-2005, 06:36 PM
DMD
DMD's Avatar
How are you able to do this? Via an FM adapter?
Old 05-26-2005, 08:04 AM
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
Post
Yes, hardwired FM modulator. Our moderator had posted a DIY a while back IIRC. A search should turn it up.
Old 05-26-2005, 11:28 AM
mudman2
Moderator !x4
mudman2's Avatar
I actually use 2 one for iPod and one for Sirius wired in serial on the antenna line and each switched.
Old 05-26-2005, 12:44 PM
ashy001
ashy001's Avatar
Does the FM modulator work in the NYC area ? What is the sound quality like, and is there a lot of interference from radio stations ?
I can't get iTrip to work around NYC due to the amount of radio stations that jam all airwaves
Old 05-26-2005, 10:39 PM
mudman2
Moderator !x4
mudman2's Avatar
You must not confuse an FM Modulator and and FM Transmitter (like iTrip). There is no problem anywhere because it provides an injected signal more powerfull than any off air signal. Works in Philly and New York very well.
An FM Modulator is wired into the antenna line.
Old 05-27-2005, 10:15 AM
ashy001
ashy001's Avatar
thanks mudman2. I am tried of waiting for denison and will install an FM modulator.
Are there different kinds of modulators ? Which is the best to install ?
Old 05-27-2005, 10:28 AM
JARO
JARO's Avatar
FM blows.....and having two is just a disaster...Have seen others and I just do not want all of these cables and other crap to be all over the dash...
Old 05-27-2005, 06:59 PM
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
Post
I'm assuming that mudman2 put the 'cables and crap' under the dash
Yes, FM may 'blow', at least from a SNR/DNR/THD+N perspective compared to line level analog (or digital audio via S/PDIF or D2B or MOST), but I'm afraid that unless Denisonusa pulls a rabbit out of their (fill in the blank), you have few choices short of full infotainment device replacement.
Old 05-28-2005, 07:45 PM
mudman2
Moderator !x4
mudman2's Avatar
Everything is under the dash above the footwell cover.
Quick Reply: DenisonUSA: new look website, update
