Lots of Coils Information -Slight Roughness at low speeds ?
Old 09-29-2016, 11:06 PM
  #166
ProgRockJunkie
ProgRockJunkie's Avatar
Checking carid, lots of options for plugs and coils. What's generally considered the best?
Old 03-06-2017, 03:10 PM
  #167
Taylorcar
Taylorcar's Avatar
Originally Posted by John Rose
My rough idle comes just as I come to a stop. Its like the Idle is too low then its rights itself after a few seconds.
This is exactly what happens to mine. It's momentary roughness and almost as though the car is going to stall just as I stop. John, were you able to diagnose your problem or is it still occurring? If nothing else I may start with coils and plugs to see where that gets me.
Old 03-14-2017, 11:13 PM
  #168
nodoors
nodoors's Avatar
This issue has been thoroughly documented. Your engine mounts have crushed down. Replacing them will resolve this.
Old 05-28-2017, 07:39 AM
  #169
Rehan1977
4th Gear
Rehan1977's Avatar
Hello people,
Very informative and helpful thread, i am driving a porsche cayenne 955 year 2005 3.2L base grade. Can someone please confirm the part numbers for upgraded coils and plugs for my ride. Thanks.
regards,
Old 07-14-2017, 04:13 PM
  #170
gkoenig
8th Gear
gkoenig's Avatar
2016 V6 Cayenne, 11k miles, progressively worse off-idle acceleration, very noticeable hesitation, slow pedal push gives 2 or 3 noticeable hesitations before normal acceleration.
Fast pedal push gives hesitation and then instantaneous, almost dangerous, acceleration.
Its gotten bad enough to warrant a dealership visit, I suspect coils based on this article. Texas temps are high this time of year, maybe heat related coil cracking.
I will report back.
Old 07-20-2017, 10:10 PM
  #171
gkoenig
8th Gear
gkoenig's Avatar
Heard from dealer today, they say it needs a new x-fer case. Again, 11k miles, bullsh_t.
Old 07-22-2017, 06:37 PM
  #172
nodoors
nodoors's Avatar
Another 958 transfer case bites the dust...
Old 09-08-2017, 12:17 AM
  #173
19psi
19psi's Avatar
Bought my '04 S two years ago with 51K miles and it just turned over 59K recently.
This summer I've been underwhelmed by the performance...seriously thought I'd just gotten acclimated to it and the thrill was over.
Decided to do the spark plugs and I couldn't find any receipts for coils so I ordered them from Pelican too. I assumed they were probably done under warranty at one point and due again.
Changed everything last night and I couldn't believe all the coils had 00 at the end, which means they are probably original. All 8 had a big crack in the same location.
Couldn't be happier with the condition of all 8 plugs.
I cannot believe the performance difference! It must have been down at least 100 hp. 2nd gear feels like what taking off in 1st used to feel like. 60 mph in 6th has the same feel as what 4th was like. Put it in 1st and romped on it while on dry asphalt and the traction control had to kick in.
Never experienced the bucking and hesitation others have.
Best $302 I've spent in a long time!
Old 10-25-2017, 02:55 PM
  #174
quickster2
quickster2's Avatar
What DTC's did you see or did you get a CEL with these bad coils?
Old 10-26-2017, 06:53 PM
  #175
19psi
19psi's Avatar
No fault codes at all.
Old 07-31-2020, 03:49 PM
  #176
Chensley
Chensley's Avatar
Looks like I am doing a coil job in my future. Purchased my 2010 GTS a little over a year ago from a Porsche dealer with 53k miles on it. Their maintenance records showed they put new plugs in it right before I got it but didn't say anything about coils. Now close to 20k miles later (yup, I've put some miles on her already) starting to notice a definite stumble at low RPMs when starting to accelerate and then even had some codes come up (P2314 Ignition coil secondary circuit, and P0355 Ignition coil E Primary/Secondary circuit). Thinking I should still be able to get another 20k miles out of the plugs though as long as they are in good condition since they are fairly new.
Old 03-05-2021, 09:22 AM
  #177
zagamuffin
zagamuffin's Avatar
I pulled coils in my wife’s 07 3.6 V6 and found V6 at marked units 033f4 111 S 18/07 , it’s a vr6 engine originally obviously but should they be Porsche marked coils ? . Is the 07 designation the original coil I wonder
Quick Reply: Lots of Coils Information -Slight Roughness at low speeds ?
