Pictures of Toyo Tires 275/40R20 on Cayenne Turbo
Old 07-13-2006, 01:36 AM
TimC.
TimC.'s Avatar
Default Pictures of Toyo Tires 275/40R20 on Cayenne Turbo
So just like some others on this forum I burned through my stock Diamaris in under 10k miles (and yes I do have a winter 18" set of Dunlops) and needed something with more wear rating. The Toyos are rated at 420 which is perfect. These pictures are from day 1. I now have about 1k miles on them and can't tell you how much I love the ride. I am spoiled though and have the air suspension, so I can play with the feel based on how aggresive I am driving which is just simply amazing !!
I had them installed by Euro Tire in NJ and they balaned both the inside and outside of the rim (something I didn't know existed) and at the same time did a 4-wheel Hunter Laser alignment. I have to say this monster drives better than the first time I drove it off the lot almost 1.5 years ago !! I want to go back and start all over again...no vibration shake etc Guess the fun just keeps getting better !! LOL
Toyo Tires Porsche Breaks World Speed Record
Link to Toyo Site
Specs:
- H and V speed-rated
- UTQG Treadwear 420
- UTQG Traction A
- UTQG Temperature A
- M and S Rated (No Thanks !! I will keep the 20" rubber in the garage and run my 18" Winter Dunlops Sept-Mar )
Pictues at various Ride Heights
Old 07-13-2006, 11:42 PM
eugkim
eugkim's Avatar
I'm trying to decide between the Proxes S/T and the Proxes 4. Will probably go with the former, although the 4's look like they would be great performers in the twisties. Treadwear is less (300 vs. 420), though.
Old 07-15-2006, 08:51 PM
TimC.
TimC.'s Avatar
Yeah I think the Proxes S/T are the way to go !! How much are you seeing them for per tire near you? I think mine were $212 per
Old 07-16-2006, 11:14 PM
cobalt
cobalt's Avatar
Received 1,949 Likes on 1,180 Posts
Tim,
10k Ouch!! I have 15k on my Perelli's and have 50% tread left.
Did Chris do your alignment? I have him do all my cars they are top notch and do a great job.
Old 07-16-2006, 11:25 PM
Grssypond
Grssypond's Avatar
Default Getting Michelin Latitude HP this week
Lets keep up Tim. I am replacing my Diamaris...now at 9k, with the Latitude HP with a 440 treadwear rating....on my '04 CTT w/ 20's. I'll post pix...not as aggressive a tread pattern...kind of a kinder more all season Diamaris.
Old 07-17-2006, 12:11 AM
User 4221
User 4221's Avatar
Tim,
I'm having a hard time finding pricing on these bad-boys...... Can you share an approximate cost?
Tx,
Scott
Old 07-17-2006, 12:18 AM
skl
Official Wednesday AM Red Bull F1 test driver
skl's Avatar
I can't seem to find any in 19" size ....
Old 07-17-2006, 11:15 AM
Vino
Vino's Avatar
Go here-
www.toyo.com/flash.html
They have them in 19" size, I have them and I love them.
They do have a 280 tread wear rating which is odd out of all the cayenne tire sizes from 18 to 20".
I do admit they are much nicer riding then the Conti's and a hell of a lot cheaper. Being that our Turbo has been alligned twice at the dealer for inner tire wear in the front, I think the originals would have lasted 15k.
We only got 10,500 out of them.
Also, I don't think the 19" Toyos are listed on tirerack.
I don't know the longevity of the tires but at 2500 miles they look fine.
Old 07-17-2006, 01:53 PM
philg3
philg3's Avatar
Personally, I am still using my original Continental 20's (front 2 were replaced FOC at about 5Kmi because of inside wear -- bad initial alignment specs), and have been very satisfied with them, but I realize that some of you have had problems with them -- particularly vibration and difficulty getting them balanced properly. While sometimes I notice a slight vibration, it's only for a few miles while they warm up; it might be a result of a flat spot when parked because I don't drive this vehicle every day. I do use Pirelli Snow and Ice during the winter, so the Continental's get a rest for half of each year, and get rotated during the switch. BTW, the back ones wear faster than the fronts on my vehicle; I always thought the fronts wore faster because of cornering / steering.
Based upon everything I've read, the Michelin Diameris are the way to go for replacements as most people here like them although some complain about the wear. Benefits discussed here are less vibration, better road force balancing, and a construction of 2 pieces rather than the typical 4. The new ones that have the N1 rating have a wear rating of twice the original N0 ones, so I'm wondering whether some of you may be basing your decisions without taking that into consideration -- were your worn out ones NO or N1? Also, there is no uniform test for wear ratings, so you can't be confident of comparing wear ratings across different manufacturers. BTW, Costco now carries the Diamaris -- you can order on the web and have them delivered to your nearest warehouse. Has anyone done that, and did their balancing machines work satisfactorily?
Old 07-17-2006, 02:24 PM
skl
skl's Avatar
I got my present Michelins at our Costco. They did a fine job installing them on the rims with no balance problems. I got a nail in one and they fixed it for no charge with a plug and patch as I'd purchased them there. I like the tires but they don't seem to be lasting any longer than the OEM Piirellis...
Old 07-17-2006, 03:35 PM
mjw930
mjw930's Avatar
I have a set of 19" Toyo's on Sport Design rims that were sold on ebay but the buyer flaked out on me. 1000 miles on the tires, 20K miles on the wheels. No road rash and straight and true.
I would like to get $1200 for the set. They will be going back up on ebay soon if there are no takers.
https://rennlist.com/forums/for-sale-ads-member-to-member-fs-wtb-free/286820-cayenne-19-sport-designs-with-toyo-st-s.html
Old 07-17-2006, 11:44 PM
eugkim
eugkim's Avatar
I'll soon be ordering the S/T's , probably toward the end of summer. I've gotten quotes from 185 to 205 installed locally. The 4's are about $20 more/tire.
Old 07-18-2006, 12:15 AM
User 4221
User 4221's Avatar
I was at Discount Tire today taking care of tires for another car and checked pricing on the Toyo's in 275/40/20. I was quoted $200 a corner.
The Diamaris I currently own were quoted at $331 a corner (N1-Spec)
I'll take the extra $520 at the next tire change interval and pocket it.
Old 07-18-2006, 05:58 PM
CJack
CJack's Avatar
OK so I made it past 10K on the Dunlops that came with the Pepper ...One day I will order rims and find a sutible tire...I am reading all these posts and threads and see several of you get rims and/or tires mounted/balanced at places like Costco and Discount Tire ...Being a little cautious, I figured the dealership would be best to have the switch made. Anyone have a strong preference on this? Dealer or outsourced to other non- Porsche folks?
Old 07-18-2006, 06:07 PM
User 4221
User 4221's Avatar
Discount is OK. They have road-force balancing which is what really matters. In fact, they have the same mounting and balancing machine my dealer uses.
A few times in the past the dealer has referred me to Discount for routine stuff like flats and balancing.
Quick Reply: Pictures of Toyo Tires 275/40R20 on Cayenne Turbo
