Towing tire pressure circus
Originally Posted by ltc
Recommended cold tire inflation pressure
These values are for cold tires (68°F/20 °C).
Interesting that Porsche recommends the same pressures for a variety of wheel/tire sizes.
Here is what VW recommends for the V8 Touareg:
HTH
Originally Posted by RJFabCab
What tire pressures are you guys running when towing under load?
Yes, Lewis, you can chime in, too!
Just picked up an '06 CS Tit Ed and here's the deal:
Tires: Pirelli Rosso N0 275/45 R19 108 XL Y
Cold pressures per the manual: 38/43 f/r partially loaded, 38/50 f/r fully loaded
Inside the driver's door, the recommended cold pressures fully loaded are 39/49 f/r.
The MAX pressure listed on the Pirelli sidewall is 50 psi. Go figure.
With a fairly loaded vehicle and towing around 5000-6000 lbs, what tire pressures are you running?
I'd hate to blow a bead or disintegrate one of the rears...
Could I ask you what kind of deal you got? How much off invoice?
