sound system
Old 05-14-2007, 01:00 PM
Tiny Tim
Tiny Tim's Avatar
Default sound system
installed a jlaudio 13w7 this weekend with the factory stock bose stereo and I must say it sounds really good! no rattles or anything. def. a good idea to add an aftermarket sub if you're into that type of thing.
kaizashozay
kaizashozay's Avatar
pics?
Old 05-16-2007, 04:46 PM
CTurbo77
CTurbo77's Avatar
I run two 12inch JL Audio W7's in my CTT.....
No rattles or annoying sounds......I did use a very minimal amount of dynomat however....
They each get 1000watts via a 2000watt USA amp.
Im under the post limit to get pics on here....but i will work on it
Old 05-17-2007, 11:51 AM
Tiny Tim
Tiny Tim's Avatar
damn i bet that is loud! the factory bose holds up pretty well. relatively easy install if you have the second battery.
Old 05-17-2007, 06:47 PM
User 4221
User 4221's Avatar
Quasi PITA install when you don't
Old 05-29-2007, 03:55 AM
dustybottoms
dustybottoms's Avatar
(my first post) I have a 2006 CS with most of the factory options. The Bose audio system w/6 disk changer, etc.
I must say however that my wifes Mini Cooper S convertible's Harman Kardon (sp)
audio system just blows mine away.
Would adding some JLs make me a contender?
--- couldn't post the pics due to it being my first post---
Old 05-29-2007, 01:16 PM
Tiny Tim
Tiny Tim's Avatar
the bass from the factory sub is non-existant. Adding a sub helped my SQ by quite a bit. The 14 speaker bose system holds up quite well with an aftermarket sub.
Old 05-29-2007, 08:02 PM
BD997
BD997's Avatar
im thinking of adding one 12" Kicker Solobaric since I need as much space in the back as possible... Should sound good enough...
Old 05-30-2007, 01:55 AM
gixxer1127
gixxer1127's Avatar
any pics?
Old 05-30-2007, 12:55 PM
Tiny Tim
Tiny Tim's Avatar
jl audio makes a stealth box with a w3. doesn't take up any trunk space.
Old 05-30-2007, 06:40 PM
BD997
BD997's Avatar
how does it sound?
Old 05-30-2007, 06:43 PM
BD997
BD997's Avatar
http://mobile.jlaudio.com/products_s...hp?fit_id=1573
Old 05-30-2007, 07:36 PM
Tiny Tim
Tiny Tim's Avatar
how does it sound?
Not sure I haven't heard one but I have had really good luck with JL Audio. How much bass do you want?
Tiny Tim
Tiny Tim's Avatar
that's the one. I guess it's a W6.
Old 06-11-2007, 08:39 PM
mambodoc
mambodoc's Avatar
Default No Bass! Mo Bass!
I was checking the forum for the exact same problem..."lack of bass despite the spare mounted sub woofer from the factory". I seems that fading from front to rear I lose all the bass! Didn't make sense to me. I thought the sub wasn't working. I unhooked it and noted little difference. Can this be? If so, can the JL Audio sub run with the existing system power or do I need an amp as well. Thanks all!
Quick Reply: sound system
