Panoramic sunroof problems...
Old 06-16-2020, 02:58 PM
  #46
ccus911
7th Gear
ccus911's Avatar
Hey Guys,
thank you for this informative thread...my pano roof was doing NOTHING and my sunshade was stuck 2” from being closed...no movement in any mode...fuses were all good...I almost ordered new switches.....After reading this thread, I pressed the **** for 15 or so seconds and the resync cleared it right up...it’s working perfectly again! Many Thanks!!!
Old 07-21-2023, 04:09 PM
  #47
UK952
UK952's Avatar
Had mine about a week, when I first got it the blind was stuck open about 6" - the re-synch cured that. Then it wouldn't open properly as channels were pretty grimy - cleaned those out and lightly lubricated - roof worked great for 3 or 4 days. Went to use it today and blind will no longer open on its switch - no noises nothing - there are some clicks from above if I try the sunroof **** but no movement. Any ideas? I guess the roof wont move until the blind retracts?
The PDF linked above doesn't seem to be available anymore, Appreciate any pointers!
Thanks,
Tony
Old 07-22-2023, 12:03 PM
  #48
UK952
UK952's Avatar
Well it worked fine again today, 1st try, so fingers crossed!
Tony
Old 10-12-2023, 06:52 AM
  #49
928 GT R
928 GT R's Avatar
Received 4,979 Likes on 1,923 Posts
Bump!
Great thread and the re-sync worked perfectly (09 Turbo).
Anyone use Triflow for lubrication? Mine is nice and clean and I do not want to corrupt the tracks with the wrong lubricant...
What lubrication is best and where should it be applied?
Quick Reply: Panoramic sunroof problems...
