Need some Advise For Cayenne PCM
Hi guys, I'm trying to install a 08Cayenne PCM into my 04 Cayenne. I would like to know do I need any wire or clips or etc in order to install this head unit? Is it difficult to install? Any hardware I need to beware? Is it able to install the back up camera? Thanks alot!
Rocky Mountain High
If you want Navigation with the 08 PCM you will have to add the DVD Nav unit under the passenger seat. If your 04 had PCM 2.0 and Nav you can use the existing antenna with an extension. For the iPod you will need a Denision or Mobridge type unit. I'm in the process of adding a back up camera via the Denison unit to my 04 which I upgraded the PCM to 2.1 from an 06.
