high pressure fuel pump failure 08 GTS....
Old 10-03-2010, 02:42 AM
997for40
997for40's Avatar
Default high pressure fuel pump failure 08 GTS....
well, i narrowed it down to the HPFP as the culprit. i had the common symptoms, delayed starting ie. 3-5 sec cranking before firing up, limp mode, sluggish & rough idle. i've already replaced rear fuel pumps & filter in the tank, plugs and check the coil packs for cracks..got better a little bit
i have read a few threads regarding HPFP failures in Cayennes and 997 Carreras and also in new BMWs. Do these manufactures get the pumps from the same company?
well, the pepper is out of warranty that's why i'm own my own, the wifey drives alot..
it has been trouble free upto 90K miles and now it can't even get ahead of corolla when merging onto the freeway...)
where is this HPFP located in the engine compartment? it will make my job alot easier.
thanks...
Old 10-03-2010, 09:25 AM
Andy E.
The V8 Porschephile
Andy E.'s Avatar
Do you find that the problem is more pronounced when extremely humid or during rain? Have you ever replaced the ignition coils?
Old 10-03-2010, 12:39 PM
carreragttech
carreragttech's Avatar
It is on the backside of the driver cam and is very easy to remove! A 10mm flex-able ratching wrench from gearwrench makes it much easier. remove the 3 long bolts and the crash shield then the 3 short that hold the pump in, then rotate the pump to remove the plug, slide out and remove. Also need to remove the two fuel lines! put back together and start car with covers still off to check for fuel leaks. Can be done in 30 min but it is a knuckle buster not alot of room in there!
Old 10-03-2010, 02:30 PM
997for40
997for40's Avatar
It started this summer, so i can't tell because it hasn't started raining yet. All i know is that it became worst after a while but I never stranded. I inspected the coil packs for cracks because I heard they were prone to this before but didn't find any and never heard them failing on the newer cayenne after they came out with a "much improved design per dealership" in my opinion a failing coil pack will give a different symptom.
HPFP symptoms @ least in my case.
3-5 sec. delay in firing up
engine vibrates when it actually starts
erratic rpm reading then settles down to normal
won't take full throttle when it hits 2700-3K rpm (bogging down)
overall runs like crap
Old 10-03-2010, 02:37 PM
997for40
997for40's Avatar
Seems like a lot easier than replacing rear pump and filter. now just have to go to my friendly neighborhood stealership to buy the part. I'll keep you guys posted.
I appreciate the help, Thanks...
Old 10-03-2010, 05:41 PM
OCNYPORSCHE
OCNYPORSCHE's Avatar
Shouldn't this be covered with the new car warranty?
Old 10-03-2010, 07:13 PM
997for40
997for40's Avatar
believe it or not wifey covered 90K trouble free miles in 2 years...what can I say she loves to drive the pepper until now...
Old 10-03-2010, 07:59 PM
OCNYPORSCHE
Wow, that must be a record. Now I can understand why a fuel pump is needed
Old 10-03-2010, 08:16 PM
Slow Guy
Slow Guy's Avatar
The HPFP is/was a very big problem with BMW x35's (as in 335/535). So much so the BMW has upped the warranty on them to 100k mi. According to the BMW boards some cars were on their 3rd and 4th HPFP. The wife's car is a 328 and is unaffected by the problem.
Good question whether the mfgrs. are the same.
Old 10-03-2010, 09:52 PM
997for40
997for40's Avatar
I'm actually surprised it lasted this long, I've read a few posting that it failed in some cars under 10K mile. IMHO it should last longer than 100K.
Old 10-03-2010, 10:28 PM
997for40
997for40's Avatar
Thats what I gathered, but in true to Porsche fashion they will not recall cars and just deal with individual warranty issues and if you're out of warranty, tough luck. I came across this issue with my 997.1. It was under CPO but when it developed a slight squeaking noise on idle, the dealership told me they have to charge me for break down and it may not even be covered under CPO. I'm glad my lease ended a couple of months ago.
Old 10-04-2010, 02:16 PM
Vino
Vino's Avatar
Do you have a check engine light on?
Just for kicks since you have a DFI motor, you may want to check for carbon build up on the intake valves if possible. This is a common issue on the DFI cars, not all. There may be a way to check for this without pulling the manifold.
When the HPFP starts to fail, I thought they just die without much stories to tell?
Hopefully it's just the HPFP pump!
Old 10-05-2010, 02:58 AM
jtpsocal
jtpsocal's Avatar
im on HPFP #2 with only 9000 miles on a 2009 Cayenne Turbo S- first one was at 4000 miles
Old 10-05-2010, 10:31 AM
Andy E.
The V8 Porschephile
Andy E.'s Avatar
Jtp, were your symptoms the same as the OP?
Old 10-05-2010, 11:30 AM
OCNYPORSCHE
2008 and later are all DFI.
Quick Reply: high pressure fuel pump failure 08 GTS....
