Porsche Cayenne Headlight issue
Old 12-22-2010, 10:06 PM
jfranz71
7th Gear
jfranz71's Avatar
Default Porsche Cayenne Headlight issue
HEY EVERYONE- THIS IS MY FIRST POST SO I HOPE THAT I CAN FIND SOME GOOD ADVISE OR HELP. MY CAYENNE'S HEADLIGHT JUST STARTED "BOUNCING AROUND" (UP AND DOWN) WHILE THEY ARE ON. NO MATTER IF I AM DRIVING OR STOPPED THEY CONTINUE TO MOVE IN A VERTICAL MOTION. THE MESSAGE CENTER INDICATED THAT THE HEADLIGHTS NEED TO BE ADJUSTED. HOW WOULD YOU DO THIS AND WHY DID IT JUST START FOR NO APPARENT REASON? THANKS EVERYONE FOR ANY ADVISE.
Old 12-22-2010, 10:24 PM
Marc Gelefsky
Super Moderator
Marc Gelefsky's Avatar
Welcome to Rennlist Captain Caps lock!
Seems likes there is an issue with the auto adjustment, I would get the car scanned by a dealer or Indy with the proper equipment.
Perhaps pull the fuses or disconnect battery for a "reboot"
Old 12-22-2010, 10:28 PM
jfranz71
7th Gear
jfranz71's Avatar
thanks marc... i will give the dealer a call. when i bought my cayenne- it was under the certified program.... do you think this would fit under the warranty?
Old 12-22-2010, 10:29 PM
Marc Gelefsky
Super Moderator
I would think it would be for sure!
And once again Welcome!
Old 12-23-2010, 02:49 AM
Dennis C
Rocky Mountain High
Dennis C's Avatar
Received 1,256 Likes on 788 Posts
There is a TSB about the light brackets loosening up with normal use. Your dealer can fix them and apply the TSB, which includes putting LocTite on the bolts to make sure they don't loosen again.
Old 12-25-2010, 01:03 AM
colo993
colo993's Avatar
jfranz71,
I had the exact same problem with my '06 Cayenne S. The dealer fixed under the warranty. From the description on the invoice the fix was to reset several of the cables that connect the headlights. So far the fix seems to have worked.
Paul
Old 12-26-2010, 06:53 AM
bigbuzuki
bigbuzuki's Avatar
Are both headlights doing it?
Are they Xenon?
If they are Xenons and cycling up and down it could be a bulb that is nearing the end of its service life.
Old 12-26-2010, 01:42 PM
Km1.8t
Km1.8t's Avatar
Check my thread on this issue, Since I changed my battery, it has not happened since. No idea why this is the case but I will take it.
Old 12-27-2010, 11:11 PM
jtpsocal
jtpsocal's Avatar
jfranz- Welcome to Rennlist. I would certainly check the caps lock button just to be safe
Old 01-01-2011, 12:29 PM
jfranz71
7th Gear
jfranz71's Avatar
thanks to all that responded.... dealer repalced the sensors - no charge.... under warranty and the problem has been resolved!
Old 02-05-2012, 06:30 PM
Chaos
Chaos's Avatar
Captian CapsLock + red, user
Old 02-04-2015, 09:23 PM
Jochy
Jochy's Avatar
Which sensors ???
Old 02-08-2015, 01:55 AM
Jochy
Jochy's Avatar
Which sensors are supposed to replace in order to avoid this beam problem..?.?
Old 02-15-2015, 01:01 PM
Jochy
Jochy's Avatar
I'm facing this same issue, the beams seems to loose the focus by moving up and down while the vehicle is stationary and sometimes running. Also sometimes if headlights are turned On, the beams stay pointing down.
Would appreciate if somebody know about the headlight sensor mentioned above, I don't really know which sensor is this one and would like to replace it to solve my issue.
TIA
Old 02-16-2015, 03:17 AM
napaul
napaul's Avatar
I'm going to take a wild stab here and assume he was speaking of the levelling sensors on the front and rear axles that tell the pitch of the vehicle and adjust the xenon lights accordingly! But I may be wrong
Quick Reply: Porsche Cayenne Headlight issue
