Upgrade Completed Now What Again???
I had the coolant upgrade done 8 months ago in my 2004 Cayenne Turbo after the plastic pipes burst. Then today I parked after a short drive and steam coming out of the engine and all the coolant was lying on the ground!!
I just replaced the drive shaft and now this!
The day before yesterday I had a weird rustling or thumping sound coming from the drivers floor, right underneath my foot but no other symptoms then it went away. it sounded like a small animal trying to escape. Could this possibly be a failed water pump? Or maybe a torn hose. It is very similar to when the coolant pipes broke.
Has anybody had a similar experience?
Good luck, it should give you another 50k before needing attention
This was corroborated by T2's recent summary of his coolant pipes fun, where he did the pipes at roughly 100K, and then the tee at roughly 200K.
Turbos only, BTW. There are several warm threads on here and sixspeed about DIY efforts on the tees. Hint: tee is harder to reach and harder to do than the pipes. And mine came off with all sorts of crusties around the metal bands.
Yup. Turns out it is the t-pipe or heater hose. It costs $14. I think the kit should include this. It should not even be an option! They would have changed it the first time if it was included. Now, I have to do a whole tear down just for a $14 plastic hose!!!
Who did the work? If it was a Porsche dealer, I'd tell them you'll pay for the part and they should cover the labor. A dealer should know better, but if it was an Indy shop - good luck.
All, So indy mechanic is now replacing the "t-pipe" but I am going to do every single other coolant pipe in the systems behind the engine that is hard to get to. I dont want to go back in a 3rd time. Is this excessive or not? Price difference is about $300. Let me know your thoughts.
