Leaking rear passenger grab handle
Old 03-07-2011, 08:34 AM
Little Green
Little Green's Avatar
Default Leaking rear passenger grab handle
Have had this happen after heavy rain and it poured here all day yesterday. The grab handle above the door in the back seat drips during heavy rains? Go to a soccer mnatch at 7 last night seat is soaked. Any ideas?
Old 03-07-2011, 08:43 AM
Veer12
Veer12's Avatar
Thumbs down
Sound Good!!!!!!!!!!!!
Old 03-07-2011, 09:35 AM
Andy E.
The V8 Porschephile
Andy E.'s Avatar
My bet would be on either a compromised polyethelene sheet that covers the door chassis just underneath the door panel or a window rubber trim/seal that's either deformed or missing which allows driving rain to enter the door chassis.
Many shade-tree mechanics will go in there to repair a window regulator or other door-resident component and won't repair or re-glue the polyethelene sheet back onto the door frame when finished. If you want to try to repair this at home, get yourself some Wurth spray adhesive which works well with polyethelene sheet.
Old 03-07-2011, 10:14 AM
Little Green
No its actually the grab handle on the inside of the ceiling not on the door. Where the convenience light is> Just a drip. Must be leaking through from the roof rails or something?
Old 03-07-2011, 10:52 AM
Divot
Much missed
Divot's Avatar
Sunroof drains plugged? Happened on my 996, but I'm not sure about the Cayenne sunroof drain location.
Quick Reply: Leaking rear passenger grab handle
