Car wont start after fuel up
Old 03-30-2011, 01:43 AM
bigbuzuki
bigbuzuki's Avatar
Originally Posted by ryan09
Thanks guys. How much did it cost for the replacement, was it done at the dealer?
Ryan
I had mine rectified under CPO warranty.
Part number is 948 110 202 01. Part name as per PET manual is "vent line, tank ventilation".
MSRP is $71.68
Sonnen Porsche has them for $51.52
Old 03-30-2011, 09:13 AM
User 4221
User 4221's Avatar
With parts and labor ~$300
Old 03-30-2011, 02:17 PM
mudman2
Moderator !x4
mudman2's Avatar
The part from Sunset is $41 plus change and its a 45 minute install, very easy
Old 03-30-2011, 02:49 PM
Slow Guy
Slow Guy's Avatar
Is this a part that should be changed for regular maintenance (like a PCV valve) or is this a part you wait until it breaks? At $41 and 45 min. I wouldn't have an issue doing it for something like the 60k mi. service if recommended.
Old 03-30-2011, 10:20 PM
ryan09
ryan09's Avatar
Anyone has a DIY guide to do this? mudman, any experience changing this yourself? If it's a easy fix I don't want the dealer doing it for 300$
Ryan
Old 03-30-2011, 10:27 PM
User 4221
User 4221's Avatar
I call it an expensive lesson..... I believe they did a purge pump with it
Old 03-30-2011, 10:32 PM
ryan09
ryan09's Avatar
Not sure what you mean by expensive lesson, the valve failed because of something I did?
Ryan
mudman2
Moderator !x4
mudman2's Avatar
I did a dyi with pictures, not in a good place to look right now try to search for "check valve"
It's only about 45 mins and the instructions I gave are very precise
Old 03-30-2011, 10:34 PM
mudman2
Moderator !x4
mudman2's Avatar
Nothing you did , they fail
Old 03-30-2011, 11:20 PM
ryan09
ryan09's Avatar
Thank you mudman, I'll look for it.
Edit: I think I found it here post #9. I'll try to follow them and update this with the result
With the pictures: here
Ryan
Old 05-20-2011, 12:16 AM
darth550
4th Gear
darth550's Avatar
Could you possibly post the link? I searched but did not find it...
Old 05-20-2011, 09:14 AM
User 4221
User 4221's Avatar
The expensive lesson was to know this was an easy DIY after I paid $$ to fix the problem.
Old 05-20-2011, 09:47 AM
mudman2
Moderator !x4
mudman2's Avatar
Here is the DIY on the Valve
you will need to remove the throttle design cover
pull up it comes right off. then you will need to remove the 4 t 30 torx screws on the drivers side coil cover.
then that cover will pull up.
Use a large flat blade screw driver or a penny to remove the 1/4 twist locks that hold down the drivers side engine compartment cover (the big black one) there should be 4 1/4 ttwists
Then remove the rearblack panel, 1 1/4 twist in the center and 2 on the pass side of it. Remove the panel
the purge valve is in the fron of the engine between the head and the intake on the drivers side .
Looks like a black cylinder little bit bigger then a film canister with a hose on one end to the front and the back is a hard black plastic line that runs along the intake and comes up in the back and goes to a rubber hose on the fire wall.
Un plug the valve and push it off its bracket, undo the clamp with a pair of plairs and pull the hose off (sometimes you need gently grab the hose with the pliars and twist to loosen it up from the valve, you can damage the valve just not the hose.
In the rear you will need to do the same, the rear hose never comes off easy I think they glue it on, use you pliars to crush the plastic line where the hose is over it. once it is crushed enough it will come off. The line is pushed into 2-3 gold clips along the intake, it will pull right out of them, You also may need to unplug the injectors on the drivers side bank just to make it easier to route.
Part number 948 110 202 01
Old 05-28-2011, 07:04 PM
darth550
4th Gear
darth550's Avatar
Did it this morning. Even though getting the hoses off was a bit of a PITA, I got it buttoned back up in about 35 minutes, just like clockwork.
CEL is off, she started right up after filling the tank and is idling nice and smooth.
Thanks again.
Old 05-29-2011, 01:36 PM
hahnmgh63
hahnmgh63's Avatar
Thanks everyone, especially you Mudman2 for the writeup. Looks like a fairly simple and cheap repair. I may go ahead and replace it on my Cayenne as a preventative measure.
Quick Reply: Car wont start after fuel up
