PCM Phone Module - Is this necessary for Bluetooth Connection?
Old 06-07-2011, 05:22 PM
thejazzman
thejazzman's Avatar
Default PCM Phone Module - Is this necessary for Bluetooth Connection?
I consider myself a Techie, but despite reading Porsche's descriptions of the Phone Module Option, I'm confused about whether I need to order it or not on my new Cayenne. I want to be able to connect my iPhone via Bluetooth to PCM.
Old 06-07-2011, 06:46 PM
Tex94
Tex94's Avatar
Originally Posted by Cartronics.com
The Porsche unit does not so Bluetooth, look at our iTronic BT - it is what most dealerships and shops are using for the Porsche to add BT and iPod if desired.
I don't think that is accurate for 2011/12 Cayenne's. Don't have mine yet but from everything I have seen and read, Bluetooth is part of PCM. So you can make and receive calls, sync your phonebook, and even play Bluetooth audio.
Old 06-07-2011, 07:02 PM
AJRDU
AJRDU's Avatar
You don't need the telephone module for the bluetooth to work in the 2011 Cayenne. The telephone module will, however, allow you to use a SIM card directly in the PCM and use the car's built in antenna for phone calls. It also allows you to do text messaging and stuff if you have the SIM card loaded in the PCM.
Old 06-08-2011, 03:24 PM
WFBlue
WFBlue's Avatar
On a recent test drive, my DroidX linked up with the PCM via BT and all of my numbers were available for dialing. The whole "download' took about 3 minutes.
Old 06-10-2011, 09:01 AM
Nemic
Nemic's Avatar
On a new Cayenne you can get Bluetooth.
We specified:
9W1 - Telephone module, and
7T1 - Porsche Communication Management (PCM) including Navigation module.
My iPhone connects to the car via Bluetooth and all of the telephone numbers are accessible from the PCM screen and also via the Multi-Function display within the instrument cluster. The scroll wheel on the steering wheel can select numbers and you can dial without taking your hand off the wheel - which is great.
We also added, UF1 - Universal Audio Interface.
This allows you to plug in a memory stick or iPhone/iPod and play all of the music tracks (mp3's) that are stored. All tracks can be accessed via the PCM screen and also from the Multi-Function display in the instrument cluster.
I use all of these functions pretty much every time I am in the car, and I think they are worth getting.
Old 06-10-2011, 12:32 PM
Nemic
Nemic's Avatar
Thats nice to have, both of those are an option in the UK.
Old 06-11-2011, 09:47 AM
Alfie
Alfie's Avatar
Bluetooth is standard. No need to order phone module.
Old 03-08-2013, 04:30 AM
Pavel Ciorici
3rd Gear
Pavel Ciorici's Avatar
I bought a 2011 Cayenne with PCM (7T1) option included.
You're saying that Bluetooth is included, but when I press on the "Phone" button from PCM it says always "Phone not available". Do you have ideas what this means?
I would like to connect my iPhone via Bluetooth.
Old 03-08-2013, 09:06 AM
grohgreg
grohgreg's Avatar
You must first pair the iPhone to the PCM.
Press the PHONE button
Press the OPTION button or touch the tab of the same name in the header
Select SET PHONE (Bluetooth Settings)
Select ACTIVATE BLUETOOTH
Proceed with the prescribed pairing process. From that point - as long as you have the iPhone turned on and within range - the PCM will automatically recognize and connect.
//greg//
Old 03-08-2013, 09:09 AM
grohgreg
grohgreg's Avatar
The Phone Module option also includes a wireless handset. A SIM card is required, which essentially gives your car it's own permanent phone number. I'd find that unhandy though, given that the calling party can't possibly know if/when you'll actually be IN the car to take a call. I saw no point in ordering it, given that the PCM/BT feature connects automatically with my iPhone. That's with me whether I'm in the car or not, which eliminates the potential missed call issue with the Phone Module.
//greg//
Old 03-08-2013, 11:59 PM
TGED
TGED's Avatar
Both Bluetooth and Universal Audio Interface are standard in Canada.
Old 03-09-2013, 04:21 AM
Pavel Ciorici
3rd Gear
//greg//
My PCM system version is 2.4.1. When I press "PHONE" button it doesn't change anything on the screen. Just a blue message appears on the button "Phone Not Available". So there is no way to access the OPTION section of the Phone. I've also followed the instructions to set up my iPhone from iPhone bluetooth settings, and also cannot find the PCM of the car. I'll call on Monday local dealer to see if they know more details about this problem.
Thanks for help!
Old 03-29-2013, 08:15 PM
THense
THense's Avatar
I have it but only use on rural road trips. It requires inserting SIM card into vehicle. Utilizes the antenna and circuitry of the car which significantly improves reception vs iPhone via Bluetooth. Not necessary.
Old 10-11-2014, 01:44 PM
dinn
dinn's Avatar
Hi there,
I do have the same problem, did you know how to make it works?
Thanks in advance
Din
Old 10-11-2014, 02:26 PM
grohgreg
grohgreg's Avatar
Mine connected just fine after I read the associated section in the Cayenne owner manual. Simple process, much less time consuming than waiting for an Internet answer
//greg//
Quick Reply: PCM Phone Module - Is this necessary for Bluetooth Connection?
