04 Cayenne s No sound from Stereo
I have the CD/AM/FM unit without NAV and today the stereo will not put out any sound from the speakers , It seems the stereo is functioning properly, but absolutely no sound is coming out from the speakers. There was no noise or static when it happened, the sound just quuit while I was driving to work. Any ideas ??? Im thinking the amplifier ?? IT has the BOSE system
Just read through another post about this problem..... I went out and drove my car , and the stereo worked perfectly ..... There has to be a cure for this problem ??? It hasn't happened in the 6 months I have owned it, but it really pisses me off that it even happens as I commute 120kms every day and a stereo is a must !
The sound is now totally gone and does not come back on .... I have it booked with the Dealer to diagnose the problem. The person I purchased the car from told me they changed out 3 Amplifiers on the car ??? IM thinking if they changed 3 amps out , there must be another problem ??
Super Moderator
Needs More Cowbell
Needs More Cowbell
Intermittent head unit fiber optic transceiver
Cracked/Bent plastic optical fiber from head unit to amplifier
Is there a CDChanger or any other infotainment options in the car?
Any aftermarket equipment (mObridge/NAV-TV, etc) now or in the past?
I doubt you would have 3 bad amplifiers ...
Where is the Amplifier located on my car? The operators manual does not show.
Moderator !x4
its above the cdc location rear passenger side behind the pull off door
if they tried 3 different amps i would go with ltc comments above he should know better than most (sic)
Super Moderator
Needs More Cowbell
Needs More Cowbell
