my P!G can't stop squealing. Now on start.
Old 05-22-2012, 10:42 PM
SCOTITUDE
SCOTITUDE's Avatar
torque converter seal. any idea when pipes were done? seal damage usually quick. if it was awhile ago and its not leaking you might be ok. its a tranny out job, yuk. google it...plenty of reading.
Old 05-24-2012, 10:14 PM
AdMan21
AdMan21's Avatar
gotcha, thanks sir...I'm not sure when the pipes were done but it was at least 4-6 months back..no leaks that I am aware of..how much is labor on this starter job typically from an Indy shop?
Old 05-25-2012, 09:50 AM
ekstroemtj
ekstroemtj's Avatar
Default starter
We had a similar problem
I would say 99% the starter is the problem
Old 05-25-2012, 11:21 PM
AdMan21
AdMan21's Avatar
I read on either Renntech or 6speed about someone just letting this go w/o replacement... and stating that if you can tolerate the noise it will last a few years, any truth to this or should I just dive in and get a new one? still need opinions on labor costs..
Old 05-26-2012, 02:05 AM
SCOTITUDE
SCOTITUDE's Avatar
I would estimate an experienced indy can swap out just the starter in a couple of hours plus 3.5-400 for the part. I guess if you can stand the noise you can uses as is until it dies.
Old 06-20-2012, 11:33 AM
pokerjarvis
pokerjarvis's Avatar
I'm in the exact same friggin' boat. Coolant tubes replaced 6 months ago; starter began screeching 4 months ago; red fluid (TCP seal) on garage floor this morning.
Wondering if anyone has used the re-man starters available online for ~$200??
This is very expensive
Old 06-20-2012, 11:55 AM
s4treg
s4treg's Avatar
I think AdMan21 ran from his Cayenne, and got a 4Runner.
Old 06-20-2012, 11:58 AM
jumper5836
jumper5836's Avatar
Once you get through the pipes and tcp seal. It's much gets better. I didn't have the alternator problem after my pipes were done. It's been almost a year now.
No problems now, just oil changes.
Old 06-20-2012, 07:10 PM
AdMan21
AdMan21's Avatar
I ran away indeed..so far the 4runner has been great, but its no Cayenne that is for sure! I don't drive the 4runner much though, my wife has taken a liking to it.
Old 06-21-2012, 08:03 PM
touareg
touareg's Avatar
Here is what work was involved with mine when I removed the engine to get at the seal.
https://rennlist.com/forums/porsche-...-pig-guts.html
Old 06-21-2012, 09:15 PM
AdMan21
AdMan21's Avatar
Holy smokes.
Old 06-21-2012, 09:49 PM
s4treg
s4treg's Avatar
Pretty cool.
Old 06-21-2012, 10:04 PM
SCOTITUDE
SCOTITUDE's Avatar
not if your doing it. P!g was definitely not designed for repair. The more i work on them the more I want to meet, and beat, the designers.
Quick Reply: my P!G can't stop squealing. Now on start.
