Air Filter
Air Filter
Going to be replacing my Air Filters in my 06S, Autohauz has some regular filters and Heavy Duty ones. Which ones should I get? Appears the "Heavy Duty" have some sort of pre-filter installed.
The Heavy duty are OEM filters just have the extra pre filter. Mann Filter
http://www.autohausaz.com/search/pro...erm=7L0129620A
Pillow (10-12-2020)
Thank you,
Charles
I recently changed my air filters. The ones I took out looked like regular filters the ones I put in had a thin foam over the filters. Not sure if it was the filters or maybe loose clamps I tightened up but afterwards I had better throttle response. The filters were not advertised as heavy duty, they there the factory replacement
