Parrot MKI9200 Installation
Does anyone have experience of fitting a Parrot MKI9200 into a 2004 Cayenne.
Its got the PCM 2 with no BOSE.
No additional harness is required, and the iso cable fits perfectly, but no power getting to Parrot.
Peter
Peter
I tried again... without changing any pins, I fit the iso adapter which came with the Parrot, and the PCM works as it should - as long as the connecter is plugged into the blue Parrot unit.
However, the parrot gets no power.
The power iso on the Porsche has 3 wires. a Red/Yellow, a Brown and a white. I'm guessing the brown is the ground, the red/yellow is constant 12v... but unsure whether the white will be a switched/ignition 12v...
I think that is what could be letting me down...
