DIY Oil Change Guide 2005 Cayenne Turbo w/ Pictures
So i recently attempted to change my oil out. Tried starting out with the lower drain plug, but looks like it's been way overtorqued from the last time someone changed it, so when i tried a 8 mm hex bolt, looks like it is stripping the allen heads.
Does anyone have any suggestions on how to get this out? Am i going to have to drill through the drain plug?
https://rennlist.com/forums/porsche-...rain-plug.html
Note: Be careful if you do this as you can f-up the pan threads = replace pan too.
