Failed Inspection Today Because of Gas Cap
Much missed
No, I'm not starting an internet hoax. I take it in for the emissions test and jokingly ask the tech if I passed. He said I failed because of the gas cap.
They hook the gas cap up to some vacuum hose thingy. The manager said these things fail all the time. So often, that someone opened a store right next door selling gas caps. $8 later and I'm good to go.
GMAFB.
GMAFB.
So
They just happened to have exactly the right gas cap to fit your year/model car?
I'm calling BS on this entire post
Just my opinion my opinion, yours may differ.
Much missed
Gas caps are VIN specific, not just year/model. There is no interchangeability and over a million possibilities. And having a steady stream of people driving past your "Failed Gas Cap, We Have Them!" sign, that just failed over a gas cap, it wouldn't make sense to carry as many styles as possible.
If NAPA has in-stock gas caps for an '04 Cayenne, why would you doubt this guy does?
Much missed
I'd have thought the same thing, but no CEL. (Kinda like if you don't close the gas cap the whole way, you get a warning.) I just think they test at a pretty high pressure. When the tech said I failed because of gas cap, I thought he was joking. I'd never even heard of a gas cap test before.
California's the only state I can think of that still does a gas cap test. It is most likely BS though, since the Cayenne's leak detection system is very sensitive to even small leaks - you would have gotten a check engine light. In fact, the reason that most states with emission testing don't require a gas cap test on newer vehicles is because the EVAP system does a self check, so scanning the car takes care of that.
Much missed
You can add AZ to your list of gas cap states. I bought a new cap for my 996 while I was at it, as it had to be tested next. I saw small cracks in the rubber o-ring inside the old cap. I'm positive that would have failed, too. Neither was throwing a CEL, or, I just ignored it, on both cars, for months. Either that, or they test the caps under much higher pressure than normal vehicle operating pressure.
Rocky Mountain High
Colorado does the gas cap check. My Audi Allroad Quattro failed a few years ago.
Its not so much that the test failure raises eyebrows...it's the bit about the guy with the gas cap shop. How many gas caps would one need to sell to pay the rent?
My old C-S failed Virginia inspection once because of the gas cap, and there was no CEL. I ordered a replacement OEM cap from Sunset Porsche, and based on the last two digits of the part number it seems they had "upgraded" the part several times, so I think they did have some issues with them.
Much missed
I'll go back, take a pic, and ask him how many gas caps he has to sell to pay the rent.
Super Moderator
Needs More Cowbell
Needs More Cowbell
I think the important question is "exactly what did Pops put into your gas tank BEFORE breaking the gas cap rushing to put it back on"
