Cayenne GTS - 6 Speed Manual Clutch Question
Rossi, Is this work being done with the engine in place?
UPDATE: no need to remove the primary cats, my mechanic worked around it. The master clutch cylinder is the one to question the Porsche engineering again, being located cramped under the fuse box. Getting close to get it all sorted.
v10rick (08-01-2020)
Would be helpful to list the part numbers for all the bits needed/recommended when complete. I’m rolling past 115k, original clutch still. No issues in my nearly 35k miles of ownership, but it’s a matter of when, and not if.
thanks
thanks
Flywheel: 955-114-012-01
Flywheel bolts (10x): N-906-651-01
Release bearing: 955-116-080-00
Rear main seal: 0PB-105-249
Transmission mount: 955-375-057-30
Slave clutch cylinder: 955-116-237-01
Master clutch cylinder: 955-423-171-02
and some brake fluid to bleed the system.
Pressure plate: 955-116-015-01
It’s time....clutch starting to slip accelerating at hwy speeds in 4-6th. Rolling towards 129k miles.
Thanks for the list Rossi
I am looking at a 958 Cayenne with a manual transmission and 136k miles. The clutch doesn't slip but I am expecting it will need to be replaced in the next 10-20k miles. When your shop replaced the clutch, did they have to remove the motor or was the transmission able to be removed without pulling the motor?
Obviously the 958 Cayenne is very different than the 955-957. There is basically no information on the if the transmission can be removed without the motor (on a 958) and I figured this may be similar.
Well, now it's my turn to do this job. I didn't see this thread and started another one. Getting the parts this week. https://rennlist.com/forums/cayenne-...procedure.html
