Free build sheet from Vin#
#91
still works. Copy and past. Replace the vin number after ?vin= with the actual vin number you want to look up.
https://admin.porschedealer.com/repo...AB2A84FK180238
#93
When I try it, it says my vehicle is not available. It is a '97. Ideas?
#94
#97
I got in using this one from page 4, not sure what the difference was, but also has to be all caps.
#101
#102
still works. Copy and past. Replace the vin number after ?vin= with the actual vin number you want to look up. https://admin.porschedealer.com/repo...AB2A84FK180238
https://admin.porschedealer.com/repo...AC29P54LA93091
#104
Received 1,143 Likes
The problem people are experiencing may be browser related. When I tried it in Chrome, typing in the entire link - I had a window open quickly and then it closed. I assume this is because the page tries to call up a printer interface to print the "report". Other times I got the VEHICLE UNKNOWN message. Dunno what the difference is.
If I opened it in Microsoft Edge (comes with Windows-10) it opens fine, and opens a printer interface as it opens.
If all else fails - try a different browser..
#105
Location: Lat: 47 Deg 26.848N Lon: 122 Deg 21.341W Seattle
I stumbled onto this link that works on my Note 2 Chrome browser -
http://admin.porschedealer.com/repor...AD29P29LA60375
Use your own VIN, and remember to use all CAPS in the VIN.
