2015 turbo excess oil consumption?
Old 10-14-2015, 04:19 PM
TomF
TomF's Avatar
Originally Posted by ineoxs
I guess I have to keep 1-2 Qtr. oil handy just in-case.
+1
I always keep 2 quarts with me at all times. My CTT hates rush hour traffic and eats more oil there than on a spirited drive.
Cheers,
TomF
Old 10-14-2015, 04:59 PM
wrinkledpants
wrinkledpants's Avatar
I used to have the same consumption. Switched to a different oil, and I no longer have to carry oil with me. 1qt/7K miles is what I consume now.
Old 10-14-2015, 09:03 PM
timwu12
timwu12's Avatar
what kind of oil did you switch from and to?
Old 10-14-2015, 09:28 PM
wrinkledpants
M1 0W40 to Shell T6. If you're under warranty, don't use T6, but find any other oil on the approval list other than M1. My oil reports put the M1 firmly in the 0W30 weigh range after a few K miles, which is way too thin given that the manual specs 40 weight as the min, and 50 weight as the max.
Old 10-18-2015, 12:56 PM
Bill P.
Bill P.'s Avatar
As an added data point, my '15 TT has 1100 miles on it (semi aggressive driving) and the oil gauge shows ⅔ full.
Old 10-20-2015, 12:28 PM
ametty
ametty's Avatar
I started commuting 104 miles each day in my 06 CTT for a month now and have added 4 quarts so far. Changing the oil this weekend..
Old 10-20-2015, 12:31 PM
wrinkledpants
Holy ****. What oil are you using?
Old 10-20-2015, 06:11 PM
timwu12
timwu12's Avatar
outta curiosity, what kinda MPG are you getting from your 104 mile daily commute?!
Old 10-23-2015, 11:03 PM
leek
leek's Avatar
Default oil consumption
08 CTT. I use a quart every 5000-6000 miles. Average mpg is 15.0 for fuel. The car has 128,000 miles and mine since new. Very good car overall although I have replaced alt, starter, coolant manifold, cardan shaft and brakes several times.
Old 10-24-2015, 06:05 PM
gnat
gnat's Avatar
Originally Posted by sapkan
I have had quite a few 500+ ps cars and none has consumed any oil. To my mind anything that comes close to 1l per 1000 kms is borderline ridiculous. I cant believe that Porsche designed it that way. My 2015 RS6's manual states that it can consume up to .8l per 1000 kms but 10 000 kms down the line and it has not touched it at all. It gets driven harder than the Cayenne too.
I don't get it either. A healthy motor should not consume significant oil during a reasonable oil change interval. Personally 10k would be too much for me, but the oil dropping a measurable amount in 5-7.5k is just obscene in my opinion.
Unfortunately too many Porsche owners just accept this BS and don't force Porsche to fix it. How the hell are you people going to know there is something seriously wrong going on?
Old 10-24-2015, 07:21 PM
wrinkledpants
Until you get a UOA on what you're running, you won't know. Many people just accept that M1 0W40 is a good oil. For many cars, it's great. For the Cayenne that needs either a 40 or 50 weigh oil, it's way too thin.
Switch to Motul. It's on the approval list, highly respected, and I bet your consumption goes way down.
Quick Reply: 2015 turbo excess oil consumption?
