Looking at a 2008 Turbo. Needs advices.
Old 09-01-2015, 12:46 PM
oups59
oups59's Avatar
Default Looking at a 2008 Turbo. Needs advices.
I am looking at a 2008 Turbo with 139,000 Km (86,000 miles). Went for a first look yesterday and the cayenne is very clean - leather looks like new . Body in very good condition, tires (21 inches) have a lot of tread remaining. Engine bay is very clean.
My questions :
  1. is 86,00 miles considered as high mileage for a turbo?
  2. Anything to look for ?
Check engine light is on ....
I am trying to get the maintenance record and I will do PPI but it will be nice to know what to look for.
Thanks for your help.
Old 09-01-2015, 02:21 PM
vchris1987
vchris1987's Avatar
Well 5 months ago I was in the same position! Mine is a 2008 CTT with 91000 miles.
-Check for rattles and cracks inside the cabin while test driving.
-Service records is a must and proof of any recalls done on the car. Mine had a few.
-While at PPI ask to remove the panels under the engine to inspect for leaks. (I had one which I thought it was something major, but turned out to be a cracked oil filter housing).
-Lower control arms are sensitive on such heavy cars at that mileage. If already done it's a +
-Check for boost leaks
-The check engine light might be nothing but it may turn out to be really $$$. The diagnostic tool will definetaly throw codes so the dealer will explain after the PPI.
Mine turned out to be an excellent car, even i spent a bit over €2000 for tyres, service and some cosmetic changes. But I had deducted them from the Asking Price.
Old 09-01-2015, 02:24 PM
mcbit
mcbit's Avatar
Not high mileage and the 957s fair far better than the 955s. I've had 2 957s with virtually nothing go wrong with them.
Old 09-01-2015, 03:03 PM
oups59
oups59's Avatar
Thanks guys.
I will dig for the maintenance records. I will also check with the dealership.
Old 09-02-2015, 03:04 AM
leek
leek's Avatar
I have a 2008 CTT purchased new in June 07 after 5 month order and receive. 126,000 miles and going very strong. Check coolant pipe manifold replacement, that is the only thing that was ever a critical failure.
Brakes come up for replacement pretty regularly depending on how you drive.
I plan to run for a few years so have replaced alt, fuel pumps, starter; I am not interested in getting stranded.
Very fun and versatile vehicle. Towed 6000# boat (maybe 7) over Cascades and Rockys, parks in condo or downtown parking space, pretty quick and responsive for a big car. Average 15 mpg over the life of the car.
Old 09-02-2015, 07:59 PM
geetee
geetee's Avatar
08 turbos are pretty solid....it's an odd year for brakes...size is 368mm a 1 year deal i think. Most years are 350 or 380mm.
Some common replacement items are fuel pumps, starters, thermostat getting stuck open.
Pretty solid overall....many 100k+miles on this board
Old 09-03-2015, 11:18 AM
TomF
TomF's Avatar
Yep. 80k miles on mine and narry a problem. Time for another new set of coil packs, however!
Cheers,
TomF
Old 09-09-2015, 01:30 PM
oups59
oups59's Avatar
Is a borescope inspection on all cylinders recommended with the PPI?
Quick Reply: Looking at a 2008 Turbo. Needs advices.
