P0491 Fault Bank 1
P0491 Fault Bank 1
Hi all,
Looking for some pix of vacuum lines etc to daignose, P0491-Secondary Air Injection System Bank .
Fuse is good... Can clear fault comes back in 2-3 weeks, seems like after hard acceleration but cant swear to that..
Runs smooth, pulls strong, no issues at all.. CEL just bugs me and I need to fix this...
Pup
(YES , I did a search)
Pup
Next time you cold start pull the hose off the bank one air pump. Start the car, how much air comes out. Should feel and sound like a leaf blower, if it does your lucky you only need the mechanical valve. There are no vac lines on a cayenne the valve is opened by the pressure from the air pump. Usually the valve sticks and the exhaust comes back up and kills the pump.
