2005 cayenne head light
driver side headlight out , pulled and noticed burnt out bulb replaced it , still no low beams , put drivers side bulb in riders side both sides went dark , then switched back and riders side worked but drivers side stayed dark , and high beams no longer work on left side soooo i in switching the bulbs i learned nothing but both bulbs show no burn out marks thanks in advance
Check the connector is lined up correctly and that the headlight is locked in correctly. Just because it went in and sits flush doesn't mean it's installed right. It takes me a few times and I find a suction cup handle stuck to the front off the light very helpful.
Thanks for the tip
