955 how to change rear brake light?
Old 02-02-2016, 01:56 AM
Edward 96 Viper GTS
Edward 96 Viper GTS's Avatar
Default 955 how to change rear brake light?
does the entire rear light assembly need to come out?
how much interior trunk area need to come out to access bulb?
Old 02-02-2016, 09:51 AM
ECS Tuning
Former Vendor
ECS Tuning's Avatar
Yes, the light assembly comes out. Remove the two screws visible with the hatch open, and then carefully pull the light out. There is a ball socket holding the outer portion of the light into the body.
Old 02-02-2016, 10:38 AM
Wisconsin Joe
Wisconsin Joe's Avatar
It's in the owner's manual. Page 335 in my 05 CTT book.
None of the interior needs to come out. Just open the hatch.
The two screws are hiding under round caps. The ball socket will break if you take the housing out more than a couple times. They are available for a couple bucks (ECS has them).
Old 02-02-2016, 11:29 AM
Edward 96 Viper GTS
is it easy to realign the light so that the body gaps are even? now the front gap is wide.
Quick Reply: 955 how to change rear brake light?
