Feel the hate. Bosch quietcast pads are braking my heart.
#31
No I guess not. I have never done it and haven't priced it and these meyle Chinese rotors aren't great. So if it was going to cost a lot I would rather just buy good rotors. Know what I mean? I also assumed it was more labor time to remove and reinstall each rotor or are they resurfaced in place?
#32
#33
#35
I would absolutely not resurface the rotors. Put on new pads and call it good. It will not significantly impact pad life.
The only negative is that the bedding process may take a bit longer as the high spots on the rotor wear into the pad to achieve 100% contact.
Resurfacing will risk making them out of true, if the operator or machine is out of calibration.
Following this advice will also spare you replacing the bolts, since you won't have to remove the caliper to change the rotor.
#37
Does anyone have experience with Ferodo pads? I got a good deal on them. I don't know what I currently have but they are super linear and you almost have to stand on the pedal for the car to stop.
#38
On my '06 S, I found the OEM set up prone to fade when braking hard corner to corner or above 100mph. I replaced with EBC yellow pads and Stoptech slotted rotors.
I haven't really tested the new set up under the same conditions I experienced fade with the OEM set up, but under normal conditions they have performed 100% identical to OEM in all regards. No squeeling, good cold performance, same dust, and a few normal hard stops have been on a dime (although again, no super high temp testing done to date).
#39
Received 1,143 Likes
One point on brake pads - almost anything you used/installed more then a year ago - is NLA. The EPA has removed copper from brake pads. Copper used to be a primary component in many pads (like all sintered pads..) New pads - my mechanic friend told me - use a high proportion of walnut shells. You might still find some copper bearing pads in "race" formulations, but the every day use pads have changed. What you knew is no longer what's available.
Some info: http://www.ecy.wa.gov/programs/hwtr/betterbrakes.html
And a google - https://www.google.com/search?q=copp...e+pads&ie=&oe= will turn up even more..
#41
I installed Bosch Quietcast on my Cayenne S prior to sale. I bedded them correctly and while they didn't have a good cold bite, for a street commuter they weren't that bad for me. Made in China though and I would not buy them again.
I love OEM pads but they dust like crazy.
I have EBC Red on my E55 and they are ok but I don't like the feel, I have a set of Pagids in the shelf that I am going to install in their place.
#42
I've figured out the main thing I hate about them. And hey maybe the shop I used botched the brake bleed. But in a panic stop they just dont bite. It takes way longer to stop abuptly. If a cat or kid jumps out the pedal feels really stiff and I have to press so hard to get anything to happen. Feels all pillowy and takes longer. For regular driving where quick deceleration isnt required they are fine.
#43
