955 Tire Sizes and Questions
Old 02-18-2016, 06:34 PM
Villian
Villian's Avatar
Default 955 Tire Sizes and Questions
I have a 2004 Cayenne S running 275/40R20's for my summer wheels and I'd like to find something beefier. What's a common size that can be run on these with both a wider tire and taller sidewall? Can you run 295/45's without rubbing? Does anyone have any pics of their Cayenne with a larger tire than a 275/40R20? Just curious.
Old 02-19-2016, 01:44 PM
Mendocino
Mendocino's Avatar
I am also curious. I've been considering some 18in wheels to get more all-terrain options. I have a mile of dirt road driveway with a couple 40degree sections, I need a little more tire than the 20's are providing.
Old 02-19-2016, 02:14 PM
bgsntth
bgsntth's Avatar
You can look at 265\50-20 Nitto Terra Grappler G2's or 275/55-20 Cooper Zeon's. These are often used by prior generation Range Rovers that want all-terrains with their 20" wheels.
I have had the Zeon's on two Rovers. A little hum over 50mph, and their wet traction\hydroplane resistance is not as good as other AT's I have utilized. They are great off-road as AT's go in terms of traction, but not durability.
Old 02-19-2016, 09:03 PM
wrinkledpants
wrinkledpants's Avatar
I run 275/45/20 for winters. They look a little better in that the fill up the wheel wells more. Once you get beyond 31.0 inches, you'll likely start rubbing. Will be dependent on the tire.
Old 02-20-2016, 02:14 AM
Villian
Villian's Avatar
Perfect. Looks like I'll be switching from 275/40's to 275/45's for my summer setup. My winters are 265/60's and that's as big as I can go with my suspension setup (H&R Sport Springs).
Old 02-20-2016, 06:11 AM
user 83838290
user 83838290's Avatar
+1.
I run 275/45 20 for winter on both of my pigs and 295/40 20 for summer on my blue pig. No rubbing whatsoever and blue one is lowered by an inch (and it's a TTS so lower than regular turbo).
Old 02-21-2016, 12:07 AM
Villian
Villian's Avatar
Originally Posted by lupo.sk
+1.
Lupo do you run the 295's on all 4? Just curious. I'm lowered by an inch or so too..and I might go that route if I can!
Old 02-21-2016, 05:37 AM
user 83838290
Yup, all 4. I bought a second set of sport technos and now I use the 9x20 all around for winter and 10x20 all around for summer
Old 02-23-2016, 01:40 AM
Villian
Villian's Avatar
Nice. Do you have any photos of the 295's on your car?
Old 05-26-2016, 12:20 AM
Cayenne81
Cayenne81's Avatar
love to see some pics too of 295 on 20 inch
Old 05-26-2016, 01:04 AM
AGARubberDuck
AGARubberDuck's Avatar
It isn't all it's cracked up to be. At least with the 295 I had on my turbo wheels. Sorry no pics, but there was a noticeable lip of tire sticking out over the wheel. Beyond that, it seemed to make the steering feel heavier. Personally I'm looking at either a wider wheel to go with a wider tire or sticking with 275/40r20 for my factory wheels.
Quick Reply: 955 Tire Sizes and Questions
